Author Topic: AR35 Gearbox  (Read 1146 times)
Tonka.
  • Lincoln, Lincolnshire
    • 2000 2.5 CDX
AR35 Gearbox
« on: 25 March 2009, 17:19:19 »
Got my new gearbox. Thanks Loo-Knee and Marks DTM  :y
Can anyone (sassanach  ;)) tell me the part number for the sonnax thrust washer? Will be replacing this before fitting box.
When I tip the box forward, I get an amount of oil leaking from around the shaft inside the bell housing. Is this normal or does it need a new centre oil seal?
I can get a seal if i need onewhen I order the thrust washer  :y
The happiest people don't have the best of everything,
they just make the best of everything they have.
Re: AR35 Gearbox
« Reply #1 on: 25 March 2009, 18:04:31 »
lol, that seals against the torque converter.
Tonka.
    • 2000 2.5 CDX
Re: AR35 Gearbox
« Reply #2 on: 25 March 2009, 18:06:11 »
I didn't know  ::)  Thanks Mark  :y
Re: AR35 Gearbox
« Reply #3 on: 25 March 2009, 18:22:27 »
This is the sonnax washer:
http://www.sonnax.com/instructions/54701-03K-IN.pdf
Part number 54701-03K
You also want a couple of seals.....which Sassanack might be able to advise on better than me!
Tonka.
    • 2000 2.5 CDX
Re: AR35 Gearbox
« Reply #4 on: 25 March 2009, 19:44:32 »
Thankyou, am on to Sassanack  :y
sassanach
  • trowbridge
Re: AR35 Gearbox
« Reply #5 on: 26 March 2009, 12:44:05 »
part no for sonnax washer is correct,part number for gasket is 96014973  and the o ring is 96017189. i would definately get the gasket but the o ring is optional(very rare that they leak)
Tonka.
    • 2000 2.5 CDX
Re: AR35 Gearbox
« Reply #6 on: 26 March 2009, 18:57:50 »
Thanks mate  :y
