Author Topic: Running Temperature  (Read 2303 times)
ScottieMV6
  • Swinton, Manchester
Running Temperature
« on: 27 March 2009, 09:45:22 »
Whatr is normal running temp for 3.0L V6??
I am finding that mine runs around the 95 mark most of the time. If I am stopped in traffic for a few minutes then it goes over 95 and the fans kick in to cool it down.
Is this completely normal or should it be running a bit cooler than that?
I'd rather be scared to death than bored to death!!
Re: Running Temperature
« Reply #1 on: 27 March 2009, 09:47:46 »
Sounds normal.....also remember that the gauges are not hugely accurate!
ScottieMV6
« Reply #2 on: 27 March 2009, 09:50:58 »
Thanks Mark. I'll cross that off the list of things to look at!  :y
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
« Reply #3 on: 27 March 2009, 12:40:02 »
I'm intrigued by the answer as mine always ran at 85 deg on the dial.
Since I had the oil cooler out and replaced the thermostat, it runs quite a bit hotter (90+) and the fans are a lot more lively.
I will be looking for air-locks etc. as I would like it to be back down where it was.
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
Black Knight
  • York
« Reply #4 on: 27 March 2009, 13:08:49 »
Had ben meaning to post the same thing.
92.5 for me.
« Last Edit: 27 March 2009, 14:57:51 by Black_Knight. »
« Reply #5 on: 27 March 2009, 13:14:47 »
Which sudgests your old stat was not closing fully.
Robmetaxa
  • Southampton
« Reply #6 on: 27 March 2009, 13:40:26 »
Could be wrong here, but arn't there differant states that open at differant temps!!!
hotel21
  • The Kingdom of Fife
« Reply #7 on: 27 March 2009, 17:40:30 »
Bear in mind the facelift and prefacelift temp guage numberings are different.
Perhaps the best rule of thumb is to have the needle at or just below halfway.  If it rises then the fans should cut in and drop it again.
ScottieMV6
« Reply #8 on: 27 March 2009, 18:05:59 »
Thanks Hotel. 95 is halfway on pre-facelift gauge so I am not going to worry about it for now.  :y
vauxmad
  • Oswestry, Shropshire
« Reply #9 on: 27 March 2009, 21:04:28 »
yeah as said above thats perfectly normal
