Author Topic: Orange engine light ON  (Read 2945 times)
Archy-01
  • Bath
« on: 26 March 2009, 12:22:25 »
Just replaced my cam cover gaskets everything is running well but i now have the orange engine light illuminated on the dash
Has anyone got any idea,s as to why
Re: Orange engine light ON
« Reply #1 on: 26 March 2009, 12:25:21 »
No idea .....  :)
But this thread might tell you ..  :)
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
Do the "pedal trick" and come back with the results .. :y :y :y
BTW .. its not uncommon to trap a knock sensor wire when doing the cam covers, or to leave something unplugged by mistake, so a good look around might help as well .. :)
« Last Edit: 26 March 2009, 12:26:26 by entwood »
Archy-01
  • Bath
« Reply #2 on: 26 March 2009, 14:36:26 »
Did the pedal trick it doesnt seem to work on automatics can you suggest anything else
cheers
« Reply #3 on: 26 March 2009, 14:40:06 »
Do it again. Works on autos and manuals
Archy-01
  • Bath
« Reply #4 on: 26 March 2009, 14:43:55 »
I sat in the car for half an hour it doesent work on my car
VX1
  • Reading, Berkshire
« Reply #5 on: 26 March 2009, 14:45:07 »
Have you connected all the sensor's back on securely?
Paul :y
Vx Trade club card holder
Halfords trade card holder
Archy-01
  • Bath
« Reply #6 on: 26 March 2009, 14:49:15 »
Yeh checked everything twice cant find anthing thats disconected
« Reply #7 on: 26 March 2009, 15:22:47 »
Does the lamp work?
« Reply #8 on: 26 March 2009, 17:39:40 »
You are doing it with the engine not running ??? aren't you .....  :(
If you do it as the instructions say you'll either get a continuously flashing lamp, which means no codes stored , or the periodic flashes you need to count.
If you get neither then you are doing something wrong... bulb can't be blown as you say it is on whilst running ???
« Reply #9 on: 26 March 2009, 18:32:07 »
Is it the EML that flashes up on the Omega when you do the pedal trick? I asked about the lamp working as I was comparing to SWMBO's Astra G. When it throws a fault up is uses one of the engine symbols (plain engine?) and uses the other (Engine with lightening strike)?? for the pedal trick. I just guessed that the later Omegas with the emmisions light did the same.  :-/  :y
« Reply #10 on: 26 March 2009, 18:33:10 »
It'd be bouncing off the limiter!!  ;)  ;)  ;)  :y  :y
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #11 on: 26 March 2009, 19:05:44 »
Nah it wouldn't. Starting with WOT causes the ECU to cut off fuel injection. It's to dry out a flooded engine same as you would with a carb.
TuBy's new whipping boy.
« Reply #12 on: 26 March 2009, 19:25:12 »
Smart arse!  ;D  ;D  :y :y :y
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #13 on: 26 March 2009, 19:51:12 »
Only know because MDTM told me. ;D
« Reply #14 on: 26 March 2009, 20:21:22 »
I did know about the WOT thing. I've had to do it with SWMBO's Hyundai and my Senator in the past. Apparently it's a common call out for the AA/RAC/etc around Christmas. Car's won't start for work because they've been started and moved a couple of feet to let friends & relatives park on drives etc and they're flooded because they were still 'on choke' when they were switched off.  :y
