Author Topic: knocking noise from front end  (Read 1088 times)
ROLFEY
« on: 29 March 2009, 14:13:08 »
Hi im back again i have got a knocking noise from the front end of my omega took advice and changed the anti role drop links but its still there it only happens when turning right and driving in straight line
when i turn left it stops and no vibration through the steering
any ideas please help :'(
« Last Edit: 29 March 2009, 14:21:49 by ROLFEY »
hotel21
  • The Kingdom of Fife
Re: knocking noise from front end
« Reply #1 on: 29 March 2009, 14:25:02 »
May be the front left wheelbearing then.
Jack up the front left corner.  Grab the wheel at the 12 and 6 oclock positions and rock in and out to feel for free play.  repeat at the 3 and 9 position.  Get an assistant to depress the footbrake then redoo the test with the footbrake applied.  If the free play disappears its the wheel bearing.  If its the same, points to a suspension bush problem.
Theres a howtoo on here for replacing the wheel bearing but be warned.  Hub nut is chuffin tight......
ROLFEY
« Reply #2 on: 29 March 2009, 14:28:47 »
thanks fr that will give it a go later will let you know how it go,s :y
