Author Topic: Fault codes  (Read 1893 times)
  • Online Online
Fault codes
« on: 28 March 2009, 18:01:23 »
Hi,
My EML has been on for a while, with these codes.
135 - Telltale checklight voltage low.
87 - A/C cutoff relay voltage low.
52- Tell tale checklight voltage high.
I changed the A/C relay and the EML went out  :), but after a while its come back on! :(
I've paper clipped it again, and the 135 code has gone. Just wondering if anyone has any ideas?
My map reading lights and heated seats arn't working either!! (fuses & bulbs are fine):'(
Any thoughts?? ::)
  • Online Online
Re: Fault codes
« Reply #1 on: 29 March 2009, 12:51:32 »
Hmmmm didn't get any answers last time I put these fault codes up either!! :(
However, I've been looking through the site and came across MDTM's post about repairing the alternator, and he mentions if the brush/regulator pack is iffy it will cause high and low voltage output.
Could this be the cause of my fault codes? and would it show up with a decent multimeter as taking the alternator out looks like a barsteward!!! :-?
Cheers in advance!
Re: Fault codes
« Reply #2 on: 29 March 2009, 13:40:42 »
check fuse 29
  • Online Online
Re: Fault codes
« Reply #3 on: 29 March 2009, 18:38:50 »
TB your're a legend!!! :y :)
Fuse 29 was indeed blown and now I've got my heated seats, map reading lights and the EML is off! :y :y :y
I only checked the fuses relating to the interior lights and heated seats!!  Also it had a 10amp fuse and the handbook says it should be 20amp hopefully thats why it went! ::)
It says in the handbook:-
" Fuse No 29 -Terminal 30: constant current for caravan/trailer."
How does this circuit affect the map lights and heated seats? and I havn't got a towbar..... :-/
Many Thanks again TB!! :)
« Last Edit: 29 March 2009, 18:55:11 by TiggerHayes »
