Author Topic: PAS pump change  (Read 1753 times)
Cameron
  • Morayshire
PAS pump change
« on: 28 March 2009, 20:20:15 »
Going to change the PAS pump tomorrow (when it's warmer!) on the ex-plod, any top tips...? (related to the job!)  ;)
TIA
Cam
« Last Edit: 28 March 2009, 20:20:35 by Kamykasie »
Welung666
Re: PAS pump change
« Reply #1 on: 28 March 2009, 20:22:24 »
TIA
Cam
You had to spoil it ;D I was cracking my fingers till I read that bit ;D ;D
Re: PAS pump change
« Reply #2 on: 28 March 2009, 20:28:09 »
TIA
Cam
A load of cat litter/oil soaking mats to collect the remnants of the ATF in the pipes. I thought I'd got most of it, but still ended up with a slick on my drive! :-?
It's all quite straight forward.  :y
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: PAS pump change
« Reply #3 on: 28 March 2009, 20:36:06 »
I just put an oil changing tray underneath, there are three torx headed bolts that hold it on and two jubilee clips iirc so nothing to hard really Cam :y
Re: PAS pump change
« Reply #4 on: 28 March 2009, 20:41:40 »
I just put an oil changing tray underneath,  .....
I knew there must've been an easier way!  ;)
Welung666
Re: PAS pump change
« Reply #5 on: 28 March 2009, 20:50:21 »
 ;D ;D ;D
Cameron
  • Morayshire
Re: PAS pump change
« Reply #6 on: 28 March 2009, 20:50:21 »
Cheers guys, didn't expect it to be too bad but nice to know before I start!  :y
Haha yes not been on here long but learning... ;)
johnnycboy
  • Colchester
Re: PAS pump change
« Reply #7 on: 28 March 2009, 22:21:06 »
Not blowing my own
but you can look here http://www.omegaowners.com/forum/YaBB.pl?num=1236366278
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: PAS pump change
« Reply #8 on: 28 March 2009, 22:24:38 »
Not blowing my own
You wish ;D
johnnycboy
  • Colchester
Re: PAS pump change
« Reply #9 on: 28 March 2009, 22:36:36 »
Not blowing my own
You wish ;D
If I had a longer neck I'd never leave home ;)
Cameron
  • Morayshire
Re: PAS pump change
« Reply #10 on: 29 March 2009, 15:03:23 »
Not blowing my own
Brilliant.  Cheers fella.  :y
Cameron
  • Morayshire
Re: PAS pump change
« Reply #11 on: 30 March 2009, 00:11:16 »
Gordon Bennett.  What an utter tw@ of a job.  >:(
Started off well enough, until it came time to remove the 3 bolts securing the pump to the engine...seems mine is slightly different to most 3L v6s, the two long bolts are installed from behind the pump - the pumps holes are threaded to take them.  Managed to get the bottom one out without too much trouble...long extension to where the oil filter is and a ratchet just fits.
The top bolt however, I couldn't even get a finger to it never mind a socket...not until I had removed the pas pipe, dipstick tube, bracket holding dipstick tube (which was secured by a bolt & nut - which you could just get a finger to) and only then could I fit a torx socket on a u/v joint to it... >:(
Then of course the realisation that the new pump won't fit because the holes are different sizes... >:(
Still, the only thing wrong with the old one was a sheared bolt.  So once out, I could remove the sheared bolt...then refit it with all the palava in reverse... started 1800, finished 2300.  Ars*. >:(
Took the opportunity, whilst it was all in bits, to fit the knife-edged TBs I've had lying around for ages and replaced the fuel filter too.
Seems to be running lovely now though, so maybe all the grazed knuckles, wrists, forarms and swearing was worth it... :-X
