Author Topic: V6 X vs Y cambelts & tensioners  (Read 1206 times)
Martin_1962
« on: 29 March 2009, 22:03:04 »
Why did they change for the Y engines?
Which is best for my 2.6?
Re: V6 X vs Y cambelts & tensioners
« Reply #1 on: 29 March 2009, 22:09:00 »
probably cost...
« Reply #2 on: 30 March 2009, 08:24:53 »
It removes an additional setup so cost reduction.
Martin_1962
« Reply #3 on: 30 March 2009, 18:22:58 »
So the earlier is better - would it fit and would it be better than the later kit?
« Reply #4 on: 30 March 2009, 19:41:29 »
IME the timing is always bang on with the fixed tensioner so no point in having an adjustable one. You'd probably have to re-use the old backplate too.
Martin_1962
« Reply #5 on: 30 March 2009, 20:23:50 »
So later kit it is then, might check on Ebay as I have enough on paypal
« Reply #6 on: 30 March 2009, 21:22:13 »
..unless you skim a load off the heads, in which case the adjustable tensioner might come in handy.
Martin_1962
« Reply #7 on: 30 March 2009, 21:30:54 »
Would be 20 thou at most (0.5mm) any more I would have to move ports and machine the inlet
