Author Topic: drivers heated seat not working  (Read 1987 times)
kingplym
  • camden, hatfield, st.neots
  • sports on, kick down
« on: 31 March 2009, 10:03:09 »
as in title my drivers heated seat isnt working but passengers is. is this just a fuse or loose wire etc
if not is it expensive?
any help would be great :y
i am willing to trade my electrical labour for parts work etc
Re: drivers heated seat not working
« Reply #1 on: 31 March 2009, 10:04:46 »
Probably heater pad in seat - common problem.
kingplym
« Reply #2 on: 31 March 2009, 10:29:49 »
any idea how to fix?
Welung666
« Reply #3 on: 31 March 2009, 10:49:18 »
Is it leather or cloth?
Leather is stitched into the seat base so can't change the pads, it's possible to use a cloth pad (as it's seperate) and fit it under the leather pad if that makes any sense?
Ridgeback
« Reply #4 on: 31 March 2009, 12:28:34 »
Sorry to butt in, same problem with mine, cloth seats.
Does the seat need to come out to replace the heated pad, and can it be done in situ.
Is there an art in getting the connectors apart from the junction box by the side of the drivers seat?
Rgds
« Reply #5 on: 31 March 2009, 12:42:33 »
« Reply #6 on: 31 March 2009, 12:45:36 »
Rgds
Two small connectors, slide out orange T-pieces under plug and press tang to release. Large connector, slide out red T-piece and press tang to release :y
kingplym
« Reply #7 on: 31 March 2009, 13:07:55 »
thanks again robg :y :y :y
« Reply #8 on: 31 March 2009, 14:57:39 »
Make sure you've had your Shredded Wheat that morning .... they're heavy! ;)  :y  :y  :y
