Author Topic: Running temperature range  (Read 1199 times)
BettyBlu
« on: 01 April 2009, 19:39:22 »
I've recently noticed a slight increase in water temps. The only reason I'm concerned is that temps were usually pretty stable around the mid point usually just below with a little increase when in standing traffic with the cooling fan kicking in to drop it again a little.
But lately it's been rising to a degree or two short of 100C in standing traffic. It still drops a few degrees but only to just above the mid point. It's never gone over 100C.
I've done all the checks, water level is good (had a full coolant drain and refill end of October last year), all hoses seem good. Not losing water anyway and it still looks clear (with a red tint.)
Is this the themostat on the way out or is this an acceptable temperature range?
Any info much appreciated!
signature pic deleted as it exceeds forum guide size....
Re: Running temperature range
« Reply #1 on: 01 April 2009, 20:35:05 »
too hot imho...
Danny S
  • Dordrecht,NL
  • Omega 2.2-16v Elegance
« Reply #2 on: 01 April 2009, 20:41:53 »
too hot imho...
Mine too,check thermo if it's opening 100% or a dirty radiator.
I don't think it's the pump,then it will be the other way around.
gr
Danny
Omega 2.2-16v Elegance Auto
Agemo
  • Cleethorpes
  • Insignia
« Reply #3 on: 01 April 2009, 21:56:58 »
Yes it does sound a bit hot, mine is always below the 90' mark, mind you, that is only according to the guage, which is not always accurate. ::)
« Reply #4 on: 01 April 2009, 21:58:06 »
Check the fuses in the ECU box.
I have also seen this before on cars where the variant coding was invalid in the instrument panel
« Reply #5 on: 01 April 2009, 22:05:51 »
OP said it was OK before, which i think rules out programming
BettyBlu
« Reply #6 on: 01 April 2009, 23:08:29 »
Ah, thanks for your responses. As it is a matter of concern I think it's worth a new thermostat immediately!
This will be my first proper DIY on the mig. Don't laugh, I haven't taken a car apart in about 20yrs!
Found thermostats @ £33.47 inc VAT. Is this a good price, made by Febi?
Cheers
