Author Topic: crank sensor buggered.  (Read 1123 times)
gav mv6
  • leicestershire
    • m/f irmscher mv6 lpg
« on: 02 April 2009, 20:17:53 »
today my love of my life died on m1 , lost revs and engine management light on according to very clever source , crank sensor has given up , now  im going round to the car tomorrow , had to leave it the old dears as very intermitant running and bein an arse , got senors in stock i just need remove old one and pop down , so my question to you good people where the smeg is it located lol i guess tis down the bottom somewhere , and how easy to do ???????
« Last Edit: 02 April 2009, 20:18:31 by xwai »
Dam its hard work getting to 250 posts .......
RolandL
  • Doncaster
    • M/facelift 2.5 V6 Elite
Re: crank sensor buggered.
« Reply #1 on: 02 April 2009, 20:26:34 »
Hello.  It's bolted next to the oil filter and runs up the back of the engine to a connector that sits at the back of the plenum.  Two ways you can do it the hard way, if you've loads of time is follow the existing route.
The easy way is to trace the cable, unbolt it from engine cut end off. bolt in new cable and run it up the side of the engine to the connector.   :y
The faster you go the bigger the grin.  Trade card user.
gav mv6
  • leicestershire
« Reply #2 on: 02 April 2009, 20:34:22 »
i guess you access it underneath the car ?
RolandL
  • Doncaster
« Reply #3 on: 02 April 2009, 20:37:49 »
Sorry, yes. Oil filter on pass side of engine, sensor bolted next to it :y
« Reply #4 on: 02 April 2009, 20:38:53 »
Dont try to use the existing route,its the proximity to the exhaust manifold that causes the problems with the sensors.
There is a guide on here somewhere,but basically you need to route the wiring up the inner wing behind the brake pipes and pull the top connector over to that side of the engine to connect it up. :y
you might as well leave the old sensor where it is,no point trying to remove it from the car.
« Reply #5 on: 02 April 2009, 20:46:57 »
