Author Topic: 3.0 V6 camshafts on 2.5 V6 ??  (Read 1664 times)
NiallyV6CDX
  • County Down
« on: 03 April 2009, 14:19:18 »
Hi all, I've just started to overhaul my 2.5 V6, and I found that the camshafts appear to be a bit worn. I am looking for more power from the engine and have been told that the 3.0 cams are a suitable upgrade for the 2.5. Does anyone have any experience with this? What sort of power gains could one expect?
Any other useful and easy/good value engine mods worth doing too? :-?
Regards, Niall
Re: 3.0 V6 camshafts on 2.5 V6 ??
« Reply #1 on: 03 April 2009, 14:24:11 »
Regards, Niall
About 18bhp
Dazzler
  • Haverhill, Suffolk
« Reply #2 on: 03 April 2009, 14:33:31 »
Regards, Niall
Yes its a very worth while mod.
Only about £100 for 20 odd bhp......Bargin 8-)
MV6Matt
  • London
    • No car since 2022....
« Reply #3 on: 03 April 2009, 14:53:08 »
Hi,
Welcome to Omega Owning! :y
3 litre cams deffo worth doing.
Could also get a better (reusable/performance) air filter and modify the box. The boy racer cones have a mixed following on this forum - dont see too many mentioned.
Remap? Depends what your after and if you want to spend the money.
When I did my cams and other bits did the exhaust too (sports cats), but thats more expense so may not be what you want to do right now.
Markey mark and ?Mutant Cav have cams available i think (got mine from Mark anyway)
Matthew
(thanks Ian)
NiallyV6CDX
  • County Down
« Reply #4 on: 03 April 2009, 16:10:51 »
Ok, great! Thanks for all that :)
I have bought a K&N large filter cone which I tried before I dismantled the heads, while I can't say it made it feel much quicker, it improved the sound amazingly and the fuel economy went up 2mpg too, so I'll probably stick that on with a pair of cold air feed pipes when Im done. As for the exhaust, I can't really afford a new set of cats for it but I was thinking of putting the twin-pipe 3.0 backbox on (the standard one looks pathetic and mine is practically rusted through anyway) and removing the secondary silencers too. I was hopin this would reduce the restriction and work with the filter (and cams) to improve the power. Has anyone else done these exhaust mods?
Regards, Niall
« Reply #5 on: 03 April 2009, 16:37:15 »
Regards, Niall
Don`t use oil-coated filters.your MAF sensor won`t like it :(
ballcock50
  • South Wales
« Reply #6 on: 03 April 2009, 16:47:59 »
I fitted 3L cams to my one V6 found it made reasonable upgrade but also had fitted improved air intake and lightened fly wheel with an upgraded 3L chip mid range was far better. If I was you I would also fit a 3L clutch plate I kept slipping the 2.5 even though it was new.
NiallyV6CDX
  • County Down
« Reply #7 on: 03 April 2009, 17:21:03 »
Regards, Niall
Ok, I'll make sure I don't re-oil it after i have washed it out (I bought it used and it seems pretty dry now anyway) Thanks 4 that :y
NiallyV6CDX
  • County Down
« Reply #8 on: 03 April 2009, 17:24:05 »
Ok I'll watch out for that, but hopefully I wont need it. Its quite a long job that I dont fancy doing.
« Reply #9 on: 03 April 2009, 21:09:18 »
Problem is, K&Ns rely on the oil to collect the dirt. If they are not regularly oiled, it goes straight through. They key is to oil them sparingly, or use the original panel filter, as they are not restrictive anyway.
