Author Topic: Locking viscous fan pulley on 2.5TD?  (Read 1741 times)
mc9
  • Luton, Beds
« on: 03 April 2009, 20:33:34 »
Can't find a way to lock the pulley so that I can remove the viscous fan. Anyone got a good method? Otherwise its out with the hacksaw and drills to make a "special" tool.
Can't find the rad drain tap -- where is it?
mc9
HGV mechanic
  • northamptonshire
  • he just keeps on going,,,
Re: Locking viscous fan pulley on 2.5TD?
« Reply #1 on: 03 April 2009, 20:56:53 »
i normal get a ring spanner and tap it off with a hammer,(the nut that is) and i belive its oppisite thread
« Reply #2 on: 03 April 2009, 20:58:29 »
mc9
Bottom hose. Don`t think the rad has got one. IIRC the drain plug is on the engine
MickAP
  • South Derbyshire
« Reply #3 on: 03 April 2009, 21:10:31 »
Yeah LH thread.
Mick
osealy
  • dublin
« Reply #4 on: 03 April 2009, 21:11:44 »
wedge a nail bar between the nuts on the pump & put a stilson on the viscous nut & hit it the wrong way . Mine came ooff on 2nd thump surprisingly. no pun intended.
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #5 on: 03 April 2009, 21:37:56 »
mc9
Rad drain tap is located at the extreme bottom nearside of rad.
It's a red slotted thumb-screw which should only unwind a few turns, and drains only about half the total volume of coolant.
For a complete coolant drain-down, there's also a drain bolt, (17mm socket/ring-spanner, from memory), located on the offside of the cylinder-block just aft of the turbo. This removes completely, so be careful not to lose it.
Your cooling system capacity is 10 litres if totally drained. So you'll need to add 5 litres of Vx antifreeze on refilling.
Viscous fan nut:
Looking at the engine from the front, I put an adjustable wrench on the nut at about the '10 past the hour' position.
Then give the wrench a sharp clout clockwise, (downwards), with a hammer.
I've not failed to slacken one yet with this method!
To tighten, jam a strongish screwdriver or pry-bar across two of the pulley bolts to counter-hold, and just pinch the nut up tight - don't 'murder' it up, there's no need .... !
« Last Edit: 03 April 2009, 21:46:00 by Reliance505 »
platty
  • Cambridge
    • BMW 530d Sport
« Reply #6 on: 03 April 2009, 22:01:47 »
As Sethsmate said, give it a tug, don't apply pressure because when it goes it will take most of your hand with it (as i found out) give it a whack and that shoudl crack it. I generally wedge a nasty great screwdriver in somewhere and hope for the best!
« Reply #7 on: 04 April 2009, 10:39:32 »
All exactly as Sethsmate says :y
