Author Topic: battery connections 2.6 facelift  (Read 4533 times)
markey mark
  • SLady bitshorpe north lincs
« on: 02 April 2009, 15:10:46 »
how do has any one got a picture of the battery connections on a 2.6 facelift ??? seem to have two wires with ring terminals on and carnt remember were they go !  :-[ :-[
markey mark
Re: battery connections 2.6 facelift
« Reply #1 on: 03 April 2009, 11:55:41 »
carnt any one help ??? 3.2 will do  :-/
« Reply #2 on: 03 April 2009, 12:00:55 »
I can take a pic tonight if that helps?
markey mark
« Reply #3 on: 03 April 2009, 12:55:22 »
cheers mark that would be spot on  :y
« Reply #4 on: 03 April 2009, 20:31:21 »
Are these any use?
markey mark
« Reply #5 on: 04 April 2009, 12:10:08 »
not really mate i have two ring terminals 6mm size on two lomg wires bound together and i dont know were they go one is brown the other is black ? do the facelifts have the earth wires on the rear lifting bracket like the pre facelifts ??? :-/
Welung666
« Reply #6 on: 04 April 2009, 12:20:32 »
If you look at the 1st pic there is a black and brown bound and bolted to the 0v terminal. Is that not the same?
« Last Edit: 04 April 2009, 12:21:08 by Welung666 »
« Reply #7 on: 04 April 2009, 12:42:46 »
No, the 2.6 doesn't.
All the ECU 0V wires connect to the 0v point under the battery.....I will get a pic later for you.
« Reply #8 on: 04 April 2009, 13:30:31 »
Does the wiring look as though it's from the factory or from later 'add-ons'?  :-/
markey mark
« Reply #9 on: 04 April 2009, 13:53:28 »
that will it then must go to the earth on battery ! andy yep its deffo factory its in main engine loom  :y
