Author Topic: Just back from service..!  (Read 2335 times)
kineavy
  • Suffolk
« on: 04 April 2009, 17:06:38 »
Got my car back from service and well it's not fantastic news
Mounting on o/s/f shock broke.
N/S rocker cover gasket leaking.
Bulge in tyre...which I knew about.
It was first time using the mechanic and he told me I could just get away with changing the shock mountings on the front and not the shocks themselves.
Has anyone had any experiance in this?
thank you in advance
Richard A
  • Aldridge, West Midlands
Re: Just back from service..!
« Reply #1 on: 04 April 2009, 18:32:17 »
Sorry don't understand about the 'broken front shock mount' !!!!
regards
richarda
richard a
jonathanh
  • coventry
« Reply #2 on: 04 April 2009, 20:01:31 »
neither do I!!!!
there isn't a lot for the shock to mount onto and nothing that is likely to break!  can you post a piccie or give us more of a clue
« Reply #3 on: 04 April 2009, 20:08:05 »
neither do I!!!!
Phew! that makes 3 of us. The front shockers are built up as part of the strut and are mounted under the inner wing & on the hub. You'd have noticed if either had broken. :o :o  ;)
kineavy
  • Suffolk
« Reply #4 on: 04 April 2009, 21:10:43 »
I just going on what he told me....There is a knocking noise from that side. I could not find what it was an he told me it was shock mount. As I say my first time using him and i just wanted some other opinions
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #5 on: 04 April 2009, 21:11:53 »
A knocking when you go over holes in the road ? that is more likely to be droplinks if so which are £15 each :y
Martin_1962
« Reply #6 on: 04 April 2009, 21:13:16 »
drop link, wishbones or idler arm
kineavy
  • Suffolk
« Reply #7 on: 04 April 2009, 21:15:26 »
Cheers guys...it's not the wishbones...I have had them replaced last year...!
kineavy
  • Suffolk
« Reply #8 on: 04 April 2009, 21:16:33 »
It's not just going over holes but any uneven road surface..!
kineavy
  • Suffolk
« Reply #9 on: 04 April 2009, 21:24:54 »
I just went out and had a look,there is play in the o/s droplink and none in the n/s. Guess I have found my problem and I know where I won't be getting it done either  >:(
I nearly went and bought new shocks today.
How big a job is it?
« Reply #10 on: 04 April 2009, 21:34:33 »
Not a big job at all! Where in Suffolk are you?
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #11 on: 04 April 2009, 22:03:28 »
Pretty easy to fit mate two nuts to undo each side  :y
« Reply #12 on: 04 April 2009, 22:06:20 »
Get em off ebay - FIA ones best - around £7 -£9 each.  Replace in pairs.  ½hr per side to do - easy and cheap job. :y
« Reply #13 on: 04 April 2009, 23:31:12 »
Could potentially be the top shock bearings...
...but far more likely something else (droplinks as you've found)
« Last Edit: 04 April 2009, 23:31:44 by TheBoy »
