Author Topic: Is 2.5 TD ECU swop possible without tech2  (Read 1536 times)
kbou55
  • Tipperary, Ireland.
  • Peace, Through Superior Firepower
« on: 03 April 2009, 23:37:23 »
I got my 2000 tractor chipped last year and im thinking of buying another 2000 tractor with less miles on it.
My question is can i straight swop the ECU's or do I need to give the Opel man loads of money to tech2 it :question :question
« Last Edit: 03 April 2009, 23:41:58 by kbou55 »
2002 Vectra 2.2 DTI Elite (for work)
2000 Zafira 1.8 Elegance (for the wife and kids)
2000 Honda Pan European ST1100 (for play)
semisheen
  • Chesterfield
Re: Is 2.5 TD ECU swop possible without tech2
« Reply #1 on: 03 April 2009, 23:52:02 »
Hi sorry i cant answer the question ....i look forward to seeing the reply though ........what did you make of the Chip ...was it worthwhille mines an auto AR35 box though ......wondering if ill feel any benifit ?
kbou55
« Reply #2 on: 04 April 2009, 00:07:52 »
Mine is a manual, turned it into a bit of an animal, well worth it.
semisheen
  • Chesterfield
« Reply #3 on: 04 April 2009, 00:15:10 »
thank you thats all i needed to know  :y
Omegatoy
  • UK
« Reply #4 on: 04 April 2009, 08:56:14 »
Hiya Buddy, glad the chip is perforing well , in regards to swapping the ecu, im pretty sure you can do it but need to change the immobilsor ring around the ignition switch and the key chips as well, as all ecu are coded to the key, so in other words you neeed both crs together to swap all the relevant parts
Omegatoy :y
Omegatoy
  • UK
« Reply #5 on: 04 April 2009, 08:57:10 »
if you didnt have an ar35 the chip wold have melted the ar 25 within a week!!!!! pm if you wants a chip!! :y
« Last Edit: 04 April 2009, 08:57:33 by Omegatoy »
« Reply #6 on: 04 April 2009, 10:23:31 »
If its same ecu type (like to be 428 on that car), just swap the chip over.
Omegatoy
  • UK
« Reply #7 on: 04 April 2009, 21:20:17 »
wouldnt he have to solder in a socket???
« Reply #8 on: 04 April 2009, 23:32:55 »
Possibly, but hardly difficult...
Around 50% seem to be socketed...
