Author Topic: Reverse Back light are off???  (Read 1234 times)
Panther79
  • Odessa,Ukraine
« on: 04 April 2009, 21:32:22 »
Hello everybody
I have a problem with reverse light they are off,I checked the fuse box everything is alright,bulbs as well were fine,if any one knows please help me
Opel Omega 2,0l 1998
Thanks for you all
HGV mechanic
  • northamptonshire
  • he just keeps on going,,,
Re: Reverse Back light are off???
« Reply #1 on: 04 April 2009, 21:35:12 »
reverse switch on gear box , most lokly the spring has snapped  :y
over50now
  • Hertfordshire
« Reply #2 on: 05 April 2009, 06:38:23 »
easy job.   Took about 30 minutes, incl putting up on ramps.
Part about £7 from vaux world :y
IAM & ROSPA Gold Grade driver
MickAP
  • South Derbyshire
« Reply #3 on: 05 April 2009, 12:17:07 »
Mine don't work so well in winter, don't know why they take an age to light up. Anyway fixed it by removing connectors to the switch on side of gearbox and sprayed with WD-40, work ok now just a little sticky in winter [smiley=cheesy.gif]
Mick
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #4 on: 05 April 2009, 13:51:55 »
Sounds like the switch - cheap and easy to change!
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #5 on: 05 April 2009, 14:39:07 »
Mick
WD40 is not the stuff to use on electrical connectors
Always use switch cleaner - you can get it from Maplins
