Author Topic: Misfire - Please help!  (Read 3291 times)
Cameron
  • Morayshire
« on: 04 April 2009, 17:19:13 »
Hey all, I got a maf from Mutantcav last weekend and I thought it had sorted the misfire...but it hasn't, I've also just replaced the o ring seals on the breather bridge/throttle assy - still there   :(
Symptoms: fine when cold (and it's fine at this point - no misfire, good response), as soon as the fast idle disengages, very rough idle and misfiring (especially bad at low revs)
Paperclip test gives (engine not running):
12
135
31
12
Please help, I'm meant to be driving down to Marham next week to track the car and this may stop that happening... :(
Welung666
Re: Misfire - Please help!
« Reply #1 on: 04 April 2009, 17:22:22 »
135 = Telltale checklight voltage low
31 = No engine RPM signal
Dount they could be connected though.
« Reply #2 on: 04 April 2009, 17:43:34 »
Any trouble starting :question
Cameron
  • Morayshire
« Reply #3 on: 04 April 2009, 17:51:50 »
Nope, she starts fine. :-/
« Reply #4 on: 04 April 2009, 18:03:27 »
EGR working OK :question
Cameron
  • Morayshire
« Reply #5 on: 04 April 2009, 18:43:33 »
I think so, would it not throw an error code if something were wrong? :-?
Cameron
  • Morayshire
« Reply #6 on: 04 April 2009, 20:42:10 »
Update:
Well I removed and cleaned the EGR valve, the IAV, the MAF and cleaned a load of connections.  Still misfiring...badly.
Took the MAF off again and cleaned the element with a dry cotton bud and reassembled.  Seemed better, but still misfiring...
Went for a drive for fuel, noticed on the way that it seemed to clear after a while at about 65mph, 2500-3000 rpm.
Got 20 ltrs of BP Ultimate and drove back, noticed it cleared again over 2500/3000 rpm...could feel it wanting to go...wee 'spurts' of released power, before clearing and pulling like a train over 3000 rpm.  When slowed down, misfire returned   :-?
Can anyone diagnose this...? :-/
« Last Edit: 04 April 2009, 20:43:23 by Kamykasie »
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #7 on: 04 April 2009, 20:45:12 »
Does this sound like a Dispack problem?
Cameron
  • Morayshire
« Reply #8 on: 04 April 2009, 20:55:08 »
It may well be, I replaced the dispack last year for a secondhand one from ebay...I also moved it to the scuttle with some longer leads.
The only thing is I think it was fine until I did the timing belt...
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #9 on: 04 April 2009, 20:59:59 »
Oh, did you have a cam locking kit when you did the cambelt? a mate of mine used to get a flatspot about 3000rpm, I checked his cambelt and it was out two teeth, I put it right and the flatspot went. Check your timing is right first as last mate :y
Cameron
  • Morayshire
« Reply #10 on: 04 April 2009, 21:03:24 »
No, I have to admit I didn't have the locking kit and it was a mare to do.  Had to do the old TDC on cyl 1 thing...3 attempts later and it was sorted.  But surely if the timing was causing this problem, it would do it when cold too?  :-?
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #11 on: 04 April 2009, 21:10:38 »
Think to start with I would be rechecking the timing with a Cam Locking Kit mate, then go from there
Cameron
  • Morayshire
« Reply #12 on: 04 April 2009, 21:14:11 »
Thanks mate, but unfortunately I don't have one and I'm travelling down south on thursday... :(
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #13 on: 04 April 2009, 21:14:46 »
Where are you?
Cameron
  • Morayshire
« Reply #14 on: 04 April 2009, 21:20:25 »
A long way-a-way, east of Inverness, northern Scotland.
Can you not still accurately check the timing using the markers?
« Last Edit: 04 April 2009, 21:21:26 by Kamykasie »
