Author Topic: crankshaft sensor  (Read 1619 times)
andy3264
  • birmingham
crankshaft sensor
« on: 03 April 2009, 06:28:32 »
Hi all, can any of you wonderfull peaople tell me where the crankshaft sensor is located on the 2.2
Re: crankshaft sensor
« Reply #1 on: 03 April 2009, 09:00:23 »
Nicely out of sight on the right side of the block behind the aircon compressor bracket (it can just about be seen from below)
andy3264
  • birmingham
« Reply #2 on: 03 April 2009, 16:22:32 »
Thanks for that DTM, now i have some more queries. Last week had cylinder head gasket and head skim done. Before this i had the mig booked in for oil and filter change on gearbox and today i had this done also.
When the head gasket went my ommisins light came on hasnt gone out since, also the engine seemed to be sluggish on acceleration and when cruising at around 40mph and above seems to miss. It feels as though it is in limp mode or too rich or lean mixture.
The gearbox centre had this on the test and they put the code reader on it and got the codes
P1550 electronic throttle control power management.
P1700 service vehicle soon request
P0340 camshaft position sensor signal incorrect
P0170 mixture lean
P1555 throttle position sensor load signal not plausable with engine load
P0130 02 sensor 1 incorrect signal
P0500 vehicle speed sensor incorrect signal
P0100 mass airflow sensor circuit low input
P0110 intake air temp signal voltage high.
So with all this info where do i start or which do i change first, please can anyone help  :-/
« Reply #3 on: 03 April 2009, 16:24:58 »
Can you redline the tacho or does it stick around the 4500rpm mark
Check all vac pipes and connector to MAF
« Last Edit: 03 April 2009, 16:29:08 by RobG »
Dazzler
  • Haverhill, Suffolk
« Reply #4 on: 03 April 2009, 16:25:05 »
I would start by taking it back to the garage that done the headgasket job  and ask them to fix it properly.
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
« Reply #5 on: 03 April 2009, 16:26:34 »
Are you sure they haven't plugged something in incorrectly, thats a lot of error codes, unless they weren't cleared after the HG failure...
Omega 2.6 V6 Elite in Shiny Black
andy3264
  • birmingham
« Reply #6 on: 03 April 2009, 16:31:52 »
You are correct mark, the error codes werent cleared after head gasket done, had planned to do it after gearbox service as both jobs were close together
andy3264
  • birmingham
« Reply #7 on: 03 April 2009, 16:38:19 »
Have just checked if i can red line it and cannot. Revs go upto 4500 then drop back to 4000 and then back up
« Reply #8 on: 03 April 2009, 16:40:59 »
Back up to 4500 :question If so that`s deffo signs of cam sensor. Still need to get codes cleared though :)
andy3264
  • birmingham
« Reply #9 on: 03 April 2009, 17:00:34 »
Yes rob, back up to 4500. Rev counter needle just goes up and down
« Reply #10 on: 03 April 2009, 17:04:30 »
I wonder if the cam sensor was not plugged back in  ::)
andy3264
  • birmingham
« Reply #11 on: 06 April 2009, 06:46:11 »
Thankyou all, will change cam sensor first then :y
« Reply #12 on: 06 April 2009, 06:51:56 »
Or do as Tunnie says and check that its actually plugged in before you buy a new one. :y
