Author Topic: Exhaust coming from oil filler cap!! - help!  (Read 8477 times)
Andy Cas
  • Swindon, Wilts
« on: 09 November 2008, 21:15:43 »
Hello, my 2.0 16v petrol omega estate (N reg) has a strange problem. Since I first bought it 2 months ago it has sounded like a diesel when cold - gummed hydraulic tappet/s I know btu this sound dies down generally, but it has been louder recently, and after a motorway run, it belched blue smoke when I accelerated on to a roundabout. When I had a look at the motor earlier, I saw a gas coming from the oil filler cap (on the intake side). When I removed the cap it was clear that exhaust was coming from it! I revved the engine and more came out! I also heard an irregular rattling noise. The gas was slightly black - unburned fuel obviously, but how the hell it it coming out this side? Anyone heard of this before? I am guessing it's... a gummed up tappet has let the camshaft damage a follower, and push a valve in the wrong manner, damaging the valve stem seal and now the valve dosen't seat properly (on the intake side), letting exhaust gases back to the intake side and up through the stem seal, out through the top..? I traced it by cleaning out the idle valve as it was gummed up - again. -Now I know why!!
Anyone heard of this before? I certainly haven't
Big golden gas guzzling luxury tardis limo
MutantCav
  • Gainsborough
Re: Exhaust coming from oil filler cap!! - help!
« Reply #1 on: 09 November 2008, 21:36:09 »
How do you sort out the gummed hydraulic tappets?
« Last Edit: 09 November 2008, 21:36:28 by ShieldOfSteel »
Abiton
« Reply #2 on: 09 November 2008, 21:42:46 »
Blow by, blocked breathers, not far from a SNAFU TBH.  ;D
Andy Cas
  • Swindon, Wilts
« Reply #3 on: 09 November 2008, 21:43:31 »
(I must get round to it) - The tappets can be removed (get a haynes book of lies), and google "cleaning hydraulic tappets" . Basically you can disassemble them and clean up the mating faces with real fine wet and dry until the internal piston slides freely, fill them back up with oil and reassemble. They then adjust themselves as they should and the engine runs silent from cold.
I am quite apprehensive about doing it though as if they are buggered (or I bugger them up), they are about 20 quid each (and I have 16 of them)
I have to take my big golden whale off the road now as I can't risk dropping a valve this early into owning it!
Andy Cas
  • Swindon, Wilts
« Reply #4 on: 09 November 2008, 21:45:48 »
What do you mean by SNAFU TBH? I havent heard that before
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #5 on: 09 November 2008, 21:50:42 »
maybe he means fubar :P
both bars though haha!
V8!!!!
Andy Cas
  • Swindon, Wilts
« Reply #6 on: 09 November 2008, 22:01:58 »
I guess it's a bit dirtier than I first thought!
I only paid 600 notes for it so I expected some hassles. Looks like it's a head off and recondition job then, hopefully not a damaged piston too. If I'm going to that trouble I may as well drop the sump out, clean out the oil pump and strainer too along with all the hoses and oilways I can get to.
That will solve the problem! Bloody vauxhalls. They're all the same.
jimmas
  • stevenage, herts
« Reply #7 on: 09 November 2008, 22:02:58 »
sounds like a mixture of worn valve stem seals and piston ring wear, both will cause blue smoke out the exhaust and one will cause blow back up through the oil filler cap were it build back pressure.
Abiton
« Reply #8 on: 09 November 2008, 22:15:07 »
Google SNAFU, I thought it was a common phrase, but contains a naughty word, so I'll not elaborate here  :o.
TBH = To Be Honest.
Meaning, overall, that your car is probably not as sick as you have decided.  There's a guide or two in the Maintenance section for getting all the breathers sorted out.  Jimmas has neatly summed up the situation with regard to the origin of the exhaust fumes.
Andy Cas
  • Swindon, Wilts
« Reply #9 on: 09 November 2008, 22:30:07 »
Yes, you are right. It has only done 98,000 miles with a good S/history, but the oil is blacker than black (obviously). Just a shame. It's the gamble you take when buying an old car. I can do all the work myself over a week or so to save on beer tokens.
Strange thing is, the exhaust is normal - clear all the time, except for twice when it belched blue smoke. Worn rings would mean a smoky exhaust all the time...?
markfree
« Reply #10 on: 10 November 2008, 09:58:05 »
Try dumping a couple of cans of Ametech (engine restore oil) into your sump - it will cure your compression problems - you can also drizzle it neat onto your valve gear which may/maynot cure your valve problems.
 It ain't cheap (about £15/250ml) but it definitely works. My old honda crv suffered from your problems and after I dumped a couple of cans in the sump and 500 miles later it was running as sweet as a nut - fleabay or AmericanTechnology.co.uk to buy :y
Martin_1962
« Reply #11 on: 10 November 2008, 10:22:43 »
Start by cleaning all of the breathers and do a couple of weekly oil changes, this SHOULD sort it.
Only after this try putting anything else in.
I would still prefer a rebuild to bunging in odd substances
Andy Cas
  • Swindon, Wilts
« Reply #12 on: 10 November 2008, 13:35:49 »
The problem really is a previous lack of maintenance. A top end rebuild WILL sort the problem. I'll do ALL the breathers and the sump / pump at the same time. Lots of work but well worth it in the end as I'll have a motor that I can confidently trust!!
I'll take pictures along the way and post the news of my success / catastrophic failure. If it goes really wrong you might see it on youtube as well. :y
« Reply #13 on: 10 November 2008, 14:09:02 »
Black oil and a good service history record sudgest a fraudulant service history record or the absolute bare minimum carried out!
In would do as sudgested, regular oil changes to help clean the internals and a good breather/throttle body clean up as a started for ten.
The statement that a top end re-build WILL sort the issues is a brace one......what IF its the oil pump worn due to poor servicing, worn bores etc?
« Last Edit: 10 November 2008, 14:09:47 by Mark »
Andy Cas
  • Swindon, Wilts
« Reply #14 on: 05 April 2009, 23:02:29 »
Hi Guys/Gals. In case anyone is interested, I finally sorted my rattly omega out.
Top end strip recondition and rebuild. It turned out that the cambelt was one tooth out on the camshaft sprockets (from the last owner doing the head gasket), and it was running "late" all the time, hence the backing up etc.
ALL the stem seals were shot along with six hyd. lifters being siezed solid. Water pump was on it's last legs too. All replaced, back together with new hd bolts, gasket, belts etc etc etc. New oil/filters and a few long runs to fill the new lifters up with oil... And it seems I have missed one lifter. It either knocks on the one lifter (too low), or horribly sticks too high, and I get one of the valves headbutting a piston. With the rocker cover off they all look identical. Ah well, I'll sort it out. Forgot to take pictures though.
I cleaned the whole car up today with the intention of selling it, but discovered that it really is a nice car when it is immaculately clean, and also discovered that the front seats tilt back!! I never knew that. It's now like driving a shiny barge down the road whilst sitting in an armchair.
