Author Topic: code reader  (Read 1180 times)
Richard148
  • solihull. w,mids
code reader
« on: 06 April 2009, 22:10:05 »
which is the best hand held (no laptop) reader? :-/
Re: code reader
« Reply #1 on: 06 April 2009, 22:12:45 »
For what car/engine? For non 2.2/2.6/3.2 Omegas, it is the real Tech2, around £4k.  For same car, for engine only, a paperclip, 5p
« Last Edit: 06 April 2009, 22:13:02 by TheBoy »
Richard148
  • solihull. w,mids
Re: code reader
« Reply #2 on: 06 April 2009, 22:20:38 »
are all the gay bay ones all s#*t
99 t plate 2.5i v6 cdx
« Last Edit: 06 April 2009, 22:22:03 by Richard148 »
Re: code reader
« Reply #3 on: 06 April 2009, 22:22:31 »
your car is not obdii compliant, so no cheap handheld scanners.  That said, generic ones can only do engine, and a paperclip can read the codes...
Richard148
  • solihull. w,mids
Re: code reader
« Reply #4 on: 06 April 2009, 22:26:12 »
just dont like the thoght of putting in paperclip in the wrong pins and poohf goes the ecu :-[
Re: code reader
« Reply #5 on: 06 April 2009, 22:28:43 »
Put it in the right holes then ;D
If you are using it a lot, consider buying an OBD plug, and shorting out said pins, then you just need to plug in your plug, and watch light on dash.
Richard148
  • solihull. w,mids
Re: code reader
« Reply #6 on: 06 April 2009, 22:37:10 »
i would intend on putting the clip in the right pins but i all ways save some space for error ;D ;D :y
