Author Topic: Steering vibes  (Read 2417 times)
jemis
  • Teesside
Steering vibes
« on: 07 April 2009, 13:18:11 »
I'm getting some steering wheel wobble at speeds of around 40 to 60 mph which is quite bad when the car is cold first thing but after about 5 minutes it gets quite a bit better, its still there but not as bad.
I have had all four wheels checked for balance and the 2 fronts where spot on and both rears where out slightly but have been rebalanced, this did not make any difference.
Could it be the idler arm.
Any thoughts.
Cheers
« Last Edit: 07 April 2009, 13:19:28 by jemis »
unlucky mark mv6
  • tipton,west mids
Re: Steering vibes
« Reply #1 on: 07 April 2009, 13:41:26 »
Could possibly be worn suspension components mate,thats all i can think of.
jemis
  • Teesside
Re: Steering vibes
« Reply #2 on: 07 April 2009, 14:25:36 »
What you thinking, bottom arms maybe.
kiwititwonk
  • west london
Re: Steering vibes
« Reply #3 on: 07 April 2009, 14:59:14 »
usually wishbones very common fault (dont i rather know it!)
£16.20+vat each from www.buypartsby.co.uk
djm1964
  • Herts
  • The Boys Are Back In Town
Re: Steering vibes
« Reply #4 on: 07 April 2009, 15:34:50 »
Sounds similiar to mine , under braking , only some of the time I am getting steering judder , then a mile down the road same speed , I break no judder ? I haven't got to the bottom of mine yet , I will try and find out what is causing it and post on here . Loo Knee & Pete seem to think Wishbone bushes ?
Take care
Dave :y
Thin Lizzy are still the the best Rock band ever ! R.I.P Phil Lynott never forgotten .
tony2
  • peterlee north east
    • 2.6 cdx auto
Re: Steering vibes
« Reply #5 on: 07 April 2009, 15:55:32 »
had same problem with my w reg facelift turned out to be warped front discs
jemis
  • Teesside
Re: Steering vibes
« Reply #6 on: 07 April 2009, 21:12:22 »
I know these do eat brake discs but in this case I'm not getting vibration under braking as I've had plenty of migs with dodgy discs and know what it feels like.
I think I might try changing the bottom arms as a starting point.
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Re: Steering vibes
« Reply #7 on: 07 April 2009, 21:14:37 »
That cured my wheel wobble :y
Trade club card holder
Code scanner available
jemis
  • Teesside
Re: Steering vibes
« Reply #8 on: 08 April 2009, 12:35:07 »
Right I've decided to go for changing the bottom arms, is it worth paying the extra for them from dealer or will aftermarket ones be ok.
Re: Steering vibes
« Reply #9 on: 08 April 2009, 12:41:22 »
Aftermarket http://www.buypartsby.co.uk/wishbone_display.php?txtmodel=Omega&Submit=Next&txtmake=VAUXHALL. And keep the old ones and get them re-bushed :y
Re: Steering vibes
« Reply #10 on: 08 April 2009, 12:53:43 »
They are 230 a side from the dealer!
Where the wheels balanced on a 5 stud balancer or a cone balancer? 5 stud cured mine. Cone balancer always in balance. They where not in balance when on the 5 stud.
If brakes judder all the time its usually brakes.
Intermittent judder usually wishbone bushes.
Its worth changing them anyway imho. They are rarely in good nic due to age alone.
