Author Topic: Air con radiator fans  (Read 1655 times)
amba
  • Medway towns
    • German V6
« on: 08 April 2009, 09:36:15 »
Is it possible to remove and replace the 2 air con radiator fans without a complete front end strip down,as I think I have a very worn bearing in one of mine and needs to be fixed soon.
Re: Air con radiator fans
« Reply #1 on: 08 April 2009, 13:17:44 »
why ? Is it noisy? Never been in there myself.
Anyone?
razzo
  • Crapital
    • 97 3.0 Elite
« Reply #2 on: 08 April 2009, 14:43:44 »
might make it easier if you remove rad & aircon condenser
amba
  • Medway towns
    • German V6
« Reply #3 on: 08 April 2009, 14:57:14 »
Was hoping I could get away without needing to remove air con rad as will then require refill.
Wasn,t sure if you could get enough access from below and through space left with front grille removed.
Sounds like a bearing is giving up in the R/H fan motor..loud screeching,have tried a dose of wd40 but must be totally sealed unit.
« Reply #4 on: 08 April 2009, 16:00:53 »
.. and, while you're here, amba06128, regarding the slightly smaller air con fan, I haven't forgotten about it. I will pull my finger out and get it sorted.  ;)
377
  • Woodhall Spa, Lincs
« Reply #5 on: 08 April 2009, 16:07:09 »
You can change just the motors with the fans attached, you need a E10 torxs type socket to undo the 3 screws, then just withdraw the motor and fan blades from the surround after unplugging the connector. The clip that holds the connector also unclips from the surround so you can pass the plug through the surround.
I can provide pictures if required
Bumper off helps a lot
« Last Edit: 08 April 2009, 16:07:45 by R_Horton »
Regards
Richard Horton
Drives  '99 Omega Elite TD (almost)  Auto Estate
amba
  • Medway towns
    • German V6
« Reply #6 on: 08 April 2009, 16:36:40 »
Kevin.........no problem....when you have time.
« Reply #7 on: 08 April 2009, 18:49:33 »
Pictures to help explain
Remove grill, bumper etc and air intake pipe so it looks like this...
Then you can get at the fans. (This part is shown on fans removed from the car, obviously you are trying to avoid this)
Remove the 3 E10 headed bolts holding the fan to the surround
(Fan removed for picture clarity... you can get to the bolts without doing this)
Disconect the plug at this point and remove the clip pictured from the surround to aid passing the plug through the surround and cut the cable tie holding the wire
Remove fan from surround
Reverse of fan
Replace with new fan and reasemble car  ;)
At no point do you need to remove aircon rad etc...
HTH
Regards
Richard Horton
amba
  • Medway towns
    • German V6
« Reply #8 on: 08 April 2009, 20:11:01 »
Cheers for that Richard...excellent description so all I need to find now is the fan motor part number and have a good laugh from local dealer when they let me know my wallet is due for open surgery...call for gas and air .....thanks again.
« Reply #9 on: 08 April 2009, 21:46:04 »
Part Number you reqire is 9 157 173 BLOWER,ASSY.,FAN (For Air Cond.)
HTH
Regards
Richard Horton
