Author Topic: Oil leak from oil pressure sensor  (Read 1436 times)
kcl
  • Finland
    • Volvo V60 D4 -14
« on: 09 April 2009, 09:44:03 »
Is this common? My engine leaks from "somewhere very low" in the front of engine, most of the oil  and crud is around the oil pressure sender. Can it be re-sealed with teflon-type pipework-sealing tape or do I buy a new sensor? Is it more likely to leak from the thread or is it the sensor itself which is leaking?
Re: Oil leak from oil pressure sensor
« Reply #1 on: 09 April 2009, 10:58:53 »
I have once or twice seen a sensor fail and it results in a fine mist around that area.
The sensors here are under a tenner so about 120NOK (sorry only localish currency I can convert) I would guess tops (although if its inflated like Norways prices then add a 0!)
« Last Edit: 09 April 2009, 10:59:41 by Mark »
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #2 on: 09 April 2009, 11:57:55 »
Thanks. FYI we are usien euros here  :)
Do you think it's of any use to take it out and re-seal it with thread-tape?
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
« Reply #3 on: 09 April 2009, 12:03:13 »
Thread tape will only be any help if it is around the thread where the leak is coming from and thats quite unlikely i think.
Omega 2.6 V6 Elite in Shiny Black
« Reply #4 on: 09 April 2009, 12:06:49 »
No, its normaly a pin hole in the pressure diaphram and hence it exits through the electrical terminal
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #5 on: 09 April 2009, 12:16:25 »
Ok, will try a new sensor then, for that price the damage is not bad. What if it ain't that one, where is the next "most common" source of leaks? Crankshaft seal I suppose, oil pan it is not...
