Pages: 1 2 [3]  All   Go Down
Author Topic: cam cover gaskets  (Read 5222 times)
NiallyV6CDX
  • County Down
Re: cam cover gaskets
« Reply #30 on: 09 April 2009, 14:36:22 »
Im doing that exact same job now and it takes quite a while to do, as you have to remove both the top and bottom intake manifold sections, multi-ram system as well as disconnecting and plugging the fuel lines and throttle coolant pipes ect...all in all very long winded but not particularly difficult, just a lot to do and lots of pipes to label!!! :o
If your cam cover seals are leaking you will probably find the spark plug wells are full of oil too, so you will need to empty all that out (I used a empty water bottle with a bit of small flexible rubber pipe to suck the oil out from the holes) and clean the surfaces and ignition coils etc. Also it is a good idea to check the condition of the manifold sealing rings (both upper and lower sets), which might need replacing.
I was quoted about 600 quid from my local specialist which i though was very OTT at the time but you can see why :D Also prices for new seals from Vauxhall seem to be ridiculous, so its probably worth shopping around for some sensibly priced ones.
That said, while there is a lot to do, its not especially difficult and you will save yourself and absolute packet, but plan on having no car for at least 3-4 days, if your spending your afternoons doing it. :y
Martin_1962
« Reply #31 on: 09 April 2009, 15:55:26 »
Your valve seals have probably gone as well, just like mine and Mike Dundees
And mine  :y
that begs two questions:
How do I know if these need changing?
How do I change them - I've looked for a guide on how to do it but can't find one?
Lots of bluey/grey smoke on start up and oil needs topping up more than normal.
Phew, I've not got the blue/grey smoke and the oil seems fine now that the CCG have been done.
Yours isn't a 2.6
« Reply #32 on: 09 April 2009, 16:00:50 »
I was quoted about 600 quid from my local specialist which i though was very OTT at the time but you can see why :D Also prices for new seals from Vauxhall seem to be ridiculous, so its probably worth shopping around for some sensibly priced ones.That said, while there is a lot to do, its not especially difficult and you will save yourself and absolute packet, but plan on having no car for at least 3-4 days, if your spending your afternoons doing it. :y
I wouldn't!
I have tried FAI, Elring and a few even cheaper ones....noen of them lasted!
Rob James
  • Sheffield
« Reply #33 on: 09 April 2009, 16:10:32 »
And mine  :y
Yours isn't a 2.6
Mine is the 3.0, what difference does it make to the valve seals and knowing if they need changing?
Cheers.
« Reply #34 on: 09 April 2009, 16:24:57 »
And mine  :y
Yours isn't a 2.6
Cheers.
Not an issue on 3.0 or 2.5, it only affects a small period of production on the 2.6 and 3.2
Pages: 1 2 [3]  All   Go Up
