Author Topic: Engine Stop  (Read 2875 times)
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
Engine Stop
« on: 08 April 2009, 21:26:16 »
Hello
I have Omega 2001 Elegance with V6 engine Y26SE and with automatic gearbox. I realized recently that when I brake with motor e.g. when appoachin traffig lights the rpm. meter start to jump between 0 and 1000 rpm. Often after this the engine stops and it is very difficult to start again. Perhaps it is the crank sensor, but it is difficult to check as the pin No. 6 does not exist anymore in these "newer" models. Earlier the only the paper clip was required.
Do you have any tips for this.
regards Polilara
Re: Engine Stop
« Reply #1 on: 08 April 2009, 21:31:52 »
Hello
regards Polilara
See the thread in Paperclip and Pedal Trick in Maintenence Guides section to read the fault codes.  Codes can be flashed out on 2.6 and 3.2 engines
Re: Engine Stop
« Reply #2 on: 08 April 2009, 21:34:54 »
And check the autobox fluid level
polilara
  • Finland
Re: Engine Stop
« Reply #3 on: 08 April 2009, 21:55:10 »
Hello, The figure concerning te paper clip idea illustrates the pin No. 6 connexted to earth. That is clear for me from older models but this pin No. 6 really does not exist anymore. There is not a connector but just an empty hole. In 4 and 5 there is a pin, both (I quess) are earth.
How to check gearbos oil level? In these newer models there is not anymore a "stick". The level is controlled with a sensor.
polilara
Re: Engine Stop
« Reply #4 on: 08 April 2009, 21:56:28 »
polilara
No, read the 'pedal trick' part of that guide that is for 2.6/3.2. Not the paperclip part that is for 2.0/2.5/3.0
tallandy
  • Lincoln
Re: Engine Stop
« Reply #5 on: 08 April 2009, 22:10:22 »
polilara
Just curious where does the Elegance model come from not heard of that thought it went Gls Cd cCx then Elite. We have Elegance zafira in the family and that was top of range
Re: Engine Stop
« Reply #6 on: 08 April 2009, 22:13:13 »
polilara
OP has an Opel - model range different
tallandy
  • Lincoln
Re: Engine Stop
« Reply #7 on: 08 April 2009, 22:31:25 »
polilara
Ah explains that then ta :) i assume there elegance is sameish as our elite or you not sure
polilara
  • Finland
Re: Engine Stop
« Reply #8 on: 09 April 2009, 05:11:55 »
Dear all
Sorry, I was too tired to read this trick part to the end It was allmost the middle of the night. Or time in Finland is + 2 hours your time. I will test this soon and come back.
polilara
polilara
  • Finland
Re: Engine Stop
« Reply #9 on: 09 April 2009, 06:10:20 »
Hello again
Code was blinked; 10 3 3 5 so the crank sensor is most propably soon in the end of its life. I change it today.
One thing I  am wondering. Why does the engine not start while crank sensor has malfunktion ? I rememer that in my Vectra having Simtec 5.6.5 the engine still started even the crank sensor was broken as the system was controlled by cam sensor and vice versa.
Polilara
Swampey
Re: Engine Stop
« Reply #10 on: 09 April 2009, 07:46:02 »
Sounds like ya Cam Shaft Sensor Is fubar
« Last Edit: 09 April 2009, 07:46:25 by Swampey »
Re: Engine Stop
« Reply #11 on: 09 April 2009, 09:09:35 »
Hello again
Polilara
just change the crank sensor,that is the crank sensor code, and go from there.
From experience here you "may" need to check the crank sensor connector is correct when ordering. There are 2 possible types for the 3.2 engine.
Not sure if the 2.6 has the same options? Anyone?
polilara
  • Finland
Re: Engine Stop
« Reply #12 on: 10 April 2009, 11:50:25 »
Hello
I took the crank sensor away and went to a local dealer. They did not have a spare so I have to wait (due to Easter time) for next wednesday.
My Omega is equipped with motor oil cooling system and the metal pipes connected to cooler are wery close to the motor block. The wire of the sensor is going between these tubes and the bloc. The gap is so small that it was really impossible to get the connector of the sensor through  that gap. So I cut the wire to get the sensor away and to show it to the dealer so that I get a right spare part. Does anyone have experience about this. Do I have to remove the tubes before installing the new sensor or can I bend...
Another question is the same I already made yesterday. Does the Motronic system not have that mode which could run the engine while e.g. the crank sensor is broken. I remember that Simtec had that mode. If e.g. crank sensor was broken the "motor lamp" in the dashboard was burning but the engine was still running controlled by  the cam sensor. Does anybody know ?
