Author Topic: AR25 now AR35 and the problem remains...  (Read 3174 times)
Tonka.
  • Lincoln, Lincolnshire
    • 2000 2.5 CDX
« on: 04 April 2009, 21:29:23 »
I got a 'new' AR35 box from a trusted breaker on OOF.
Drained the oil, fitted a new filter, set the clutch.
Removed old AR25 and fitted AR35. A hard but enjoyable job.
Filled correctly with Fuchs Dex II.
Now, the 'new' box is behaving just like the old box but not as harshly.
It holds second gear and thumps into third with a jerk.
This seems too much of a coincedence. Can anybody think of a common fault which may cause this ?
I really don't want to rip another gearbox out this year  ::) ::) :y :y
The happiest people don't have the best of everything,
they just make the best of everything they have.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: AR25 now AR35 and the problem remains...
« Reply #1 on: 04 April 2009, 21:31:11 »
Thought gearboxes are supposed to have Dex III gearbox oil?
Tonka.
    • 2000 2.5 CDX
« Reply #2 on: 04 April 2009, 21:33:32 »
Typo. Should read DEX III  :-[ :-[
Been a long day  :y :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #3 on: 04 April 2009, 21:34:38 »
Sorry mate :-[
Tonka.
    • 2000 2.5 CDX
« Reply #4 on: 04 April 2009, 21:36:30 »
Sorry mate :-[
Worry not bud, worry not  :y
jack68
  • Berkhamsted Hertfordshire
« Reply #5 on: 04 April 2009, 22:00:33 »
I'm in Lincoln this weekend if you want a hand?
JACK
iainb
  • West Midlands
« Reply #6 on: 04 April 2009, 22:10:57 »
Did you disconnect the battery when you changed the box ?
Your fault sounds like it was held in the transmision memory somehow.
What you could try is to lock the POS & NEG battery leads together (battery disconnected)and leave for several hours and that should clear any stored memory.
Or get a tech 2 and see whats going on !
Tonka.
    • 2000 2.5 CDX
« Reply #7 on: 04 April 2009, 22:16:23 »
JACK
Thanks jack. Got it in, don't want to take it out again. Bloody heavy on the driveway  ;) :y
Tonka.
    • 2000 2.5 CDX
« Reply #8 on: 04 April 2009, 22:19:12 »
Had it on TechII (Marks DTM) last week. Showed a gearbox fault (the AR25). Classic thrust bearing failure.
I can lock the leads together. Worth a try. Thanks  :y :y
jack68
« Reply #9 on: 04 April 2009, 22:23:44 »
No problem i'm around anyway and if you PM me i can give you my contact number.
JACK
« Reply #10 on: 04 April 2009, 22:27:50 »
Are you using the same torque converter?
Tonka.
    • 2000 2.5 CDX
« Reply #11 on: 04 April 2009, 22:29:09 »
Yes. The one out of the AR25.  :-/
« Reply #12 on: 04 April 2009, 23:25:38 »
What was the faultcode?
Tonka.
    • 2000 2.5 CDX
« Reply #13 on: 04 April 2009, 23:52:29 »
I don't know. maybe Mark remembers  ::)
Tonka.
    • 2000 2.5 CDX
Re: AR25 now AR35. Thanks to OOF......
« Reply #14 on: 11 April 2009, 09:33:16 »
Well its been a week now. Checked the level last Monday and topped up by about 150ml.
The box seems to have settled down and is performing as it should  ;D
Many thanks to you guys, mainly Marks DTM, for giving me the confidence to attack this daunting task. :y
Thanks to Mark and Chris for offering their time to supply and fit a new box.  :y
[size=12]
Thankyou all[/size]
 8-) 8-) :y
« Last Edit: 11 April 2009, 09:35:39 by Tonkapaj »
