Author Topic: Cruise control  (Read 1271 times)
mccarthy
  • southampton
Cruise control
« on: 10 April 2009, 18:08:40 »
Can I retro fit an early model cruise control on to my 2001 Omega 2.0ltr facelift.
Mac
jonathanh
  • coventry
Re: Cruise control
« Reply #1 on: 10 April 2009, 18:21:23 »
yep
need actuator, cruise stalk, 4 pin brake switch and poss clutch switch.  plug them in and off you go.  make sure you get the actuator from  2.0 as the bowden cable for the V6 may be shorter
mccarthy
  • southampton
Re: Cruise control
« Reply #2 on: 10 April 2009, 20:28:48 »
Thanks Jon,
I`ll give it a try.
Mac
Re: Cruise control
« Reply #3 on: 10 April 2009, 22:28:05 »
Methinks facelifts will also need a chat with Tech II :)
Re: Cruise control
« Reply #4 on: 10 April 2009, 22:52:52 »
not on a 2.0l
Re: Cruise control
« Reply #5 on: 10 April 2009, 23:06:46 »
not on a 2.0l
I stand corrected :-[
Re: Cruise control
« Reply #6 on: 11 April 2009, 08:47:06 »
not on a 2.0l
Remember its not the fact its a facelift, for get that. Its the engines.
2.0/2.5/3.0 - No tech II as its all mechanical
2.2/2.5TD/2.6V6/3.2V6 - Required Tech II as the throttle is electronically controlled  :y
(usually 2.5TD already have it enabled!)
« Last Edit: 11 April 2009, 08:48:04 by tunnie »
Re: Cruise control
« Reply #7 on: 11 April 2009, 10:26:06 »
not on a 2.0l
2.5TD always has it enabled - there is no ability to disable it.
Re: Cruise control
« Reply #8 on: 11 April 2009, 11:39:47 »
not on a 2.0l
Thats cause they are designed to be in vehicles that plough fields  ;D
