Author Topic: More LPG help please!  (Read 3286 times)
HolyCount
« on: 09 April 2009, 18:37:13 »
Okie dokie .... I managed to get hold of the software and interface for the LPG kit. When I tried to fire it up before it just switched back to petrol right away.
So, after spending a little while trying to get the screen to display in English, I plug in and start the car. Go to Diagnostics where I can switch over to gas and the engine still runs smoothly on LPG and stays on LPG.
Go to Autocalibrate and it runs through setting up at idling speed, then asks for 2800 - 3200 revs, at which point it hangs (about 1/3 way through the autocalibrate sequence). Alll the readings are slightly fluctuating, indicating to my simple mind that the programme hasn't frozen ---- I am afraid after 5 - 10 mins I exited autocalibrate as my patience had worn out.
However the car sat there quite happily running on gas --- until I disconnected from the lappy, at which point it switched over to petrol right away!!!!  >:(
Now, with the car running on petrol, if I try to switch to gas the gas light flashes and a red indicator above it comes on and an alarm sounds ( bong) --- as I would expect if gas was about to run out maybe ?  :-?  But, gas tank is full and gas does get through when connected to the mapping software !!!!
Any ideas ?  And what should I be looking for when in diagnostic mode?  It tells me the injectors are the correct size, Lambda measures 3.1V and the times for the gas and petrol injectors read at roughly the same as each other ( I assume this is good).
Help !!!!!!
Re: More LPG help please!
« Reply #1 on: 09 April 2009, 20:44:31 »
HC, Have you tried giving the throttle a little blip as it may be set to only switch over at a certain RPM.
Better still... Take some screen shots of the settings and post them on here... I know it'll all be different to the AC software we're used to seeing but we might just be able to suss it out for you :y :y :y
« Reply #2 on: 09 April 2009, 22:55:20 »
Something else to try. Is there a gas pressure threshold for switchover to petrol? Just wondering iff the gas pressure is too low and causing it to switch back.
HolyCount
« Reply #3 on: 09 April 2009, 23:21:36 »
That could well be it ----- seem to remember the pressure being 0.8 bar and have a feeling that it should be higher for 6 cylinders ---- we may be on to something there  :)
Would help if I could get hold of a manual or something but have Googled for hours with no luck !!
HolyCount
« Reply #4 on: 10 April 2009, 13:27:40 »
Just a thought, though, if the pressure is too low, how come it runs OK when autocalibration is in progress ( even when the process seems to hang)?   :-/
« Reply #5 on: 10 April 2009, 13:40:57 »
I wonder if having the laptop connected allows you to force it to gas whereas without some condition is preventing this? I don't know the system so it's not easy to say.
I would have a careful look at the settings for the conditions for switching to and from gas against the live data and see if anything looks amiss.
HolyCount
« Reply #6 on: 11 April 2009, 15:42:22 »
Thanks for the assist Kev and Lazy :y
After about 6 months "Googling" I have finally tracked down a copy of the install manual and Technical Manual !
So -- have a bit of reading to do and take it from there  :)
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
« Reply #7 on: 11 April 2009, 16:25:17 »
What make of LPG kit do you have?
Omega 2.6 V6 Elite in Shiny Black
HolyCount
« Reply #8 on: 11 April 2009, 17:56:38 »
Zavoli Alisei
bconnelly
  • Edinburgh - Scotland
« Reply #9 on: 11 April 2009, 18:15:59 »
Sorry im not here to offer any practical help but as you've been Googling and made more progress than me, can you siggest any good web sites or some place I might be able to source the software and interface for a Necam Koltec LPG system.
Cheers
BC
HolyCount
« Reply #10 on: 11 April 2009, 18:40:35 »
Cheers
BC
Haven't come across that one (as I wasn't looking for it!), but have an ask here:
http://www.lpgforum.co.uk/
« Reply #11 on: 11 April 2009, 18:58:37 »
Cheers
BC
You'll struggle TBH!
Good luck... The forum link above is well worth a look :y :y
HolyCount
« Reply #12 on: 11 April 2009, 19:11:06 »
As Lazydocker says --it will take some finding being a factory fit too.
« Reply #13 on: 11 April 2009, 19:31:32 »
The Koltec/Necam kit used as factory fit was never up to the job TBH... And it's also a different type of system. There are a couple of guys on www.lpgforum.co.uk who know this system quite well but AFAIK there is now only one LPG Specialist who understands the system... Millbrook IIRCC
« Reply #14 on: 11 April 2009, 19:32:15 »
Zavoli Alisei
Have you tried contacting either Zavoli or the UK importer?
