Author Topic: Oil in header tank  (Read 1681 times)
4huftys
  • Worcester Hereford boarder
Oil in header tank
« on: 12 April 2009, 13:36:03 »
there is just a film of brown sludge on top of the water in the header tank is this possible the start of the oil cooler going.thanks
Re: Oil in header tank
« Reply #1 on: 12 April 2009, 13:37:38 »
yup
« Reply #2 on: 12 April 2009, 13:38:00 »
and don't use until replaced
johnh001
« Reply #3 on: 12 April 2009, 13:42:35 »
Or possible head gastet  :(
« Reply #4 on: 12 April 2009, 13:53:45 »
A) Its an Elite, so V6 (or diesel), and HG don't fail on those
B) Even if it did, you would not get oil in water (but may get water in oil) on this engine
MutantCav
  • Gainsborough
« Reply #5 on: 12 April 2009, 14:17:27 »
They do but very rarely and usually only as a result of the owner driving the car even though its overheating due to (for example) oil cooler failure...
Justdave
  • Merseyside
« Reply #6 on: 12 April 2009, 14:58:20 »
A cracked head would give you oil in the water ! but if as you say it's not a common fault let's hope it's that !
« Reply #7 on: 12 April 2009, 15:03:25 »
Not head gasket - oil in water=oil cooler going or gone.
Awkward job to replace but well doable.  Parts just over £100 from Vx on Trade Club Card.
johnh001
« Reply #8 on: 12 April 2009, 16:59:04 »
Hey you can tell I'm a newbie  ;D
« Reply #9 on: 12 April 2009, 17:00:42 »
;D
I was more trying to put the poster's mind at rest, rather than dis what your were saying, as HG failures on the GM V6 are rare as rocking horse poo
V6Astra F
  • Heidelberg , South Africa
  • 3.2 V6 Powered Kadett
« Reply #10 on: 12 April 2009, 17:23:56 »
hi
had the same problem last week , almost got a heart attack  :o . But it was the cooler that had a small leak so it wasnt so bad. I hope you get your car sorted out fast goodluck  :y
