Author Topic: how 2 remove fault reminders on computer  (Read 1265 times)
deecee
« on: 11 April 2009, 16:15:19 »
3 fault reminders keep appearing on computer after i have fixed them,ie brake light ,taillight ,rearlight it says they will erase themselves this is not happening can someone advise thanks deecee
Re: how 2 remove fault reminders on computer
« Reply #1 on: 11 April 2009, 16:18:30 »
You've either still got the faults ....  ::) or you could try a new quality lamps. Cheap lamps can, apparently, upset the check control
« Reply #2 on: 11 April 2009, 16:20:40 »
Omegas are quirky about makes of bulbs fitted.  Vx are OK, Halfords can be problematical.  I use Ring which seem ok.
deecee
« Reply #3 on: 13 April 2009, 15:25:24 »
thanks lads, will check deecee
