Author Topic: paper clip advice  (Read 1228 times)
colv6
  • liverpool
    • 2002 2.6 cd
paper clip advice
« on: 17 April 2009, 13:46:17 »
hi, as title advice needed,
1999 v reg 2.5 v6 estate.(facelift)
just paper clip tested not the results i expected ie 12 and 31 plus any faults.
the results i got are 12 and 19 ? only done with ignition on not tried with engine running.
i have a headlight low warning so i expected something to do with sensors or headlight adjusters also i slight misfire i was hoping for some clues from this test.
col
1998 3ltr elite (RIP rearended)
Re: paper clip advice
« Reply #1 on: 17 April 2009, 13:55:40 »
col
19 is stored code for crank sensor (are you experiencing intermittent starting probs). Does the MID say "headlight field beam/vision" or similar. If so, check front and rear passenger side sensors, link arm on sensor may have popped off
colv6
  • liverpool
    • 2002 2.6 cd
« Reply #2 on: 17 April 2009, 14:03:34 »
no starting problems at all,
checked the two link arms both ok removed and cleaned the electrical conections still headlight vision warning hence doing paper clip test to try and narrow the fault down a bit.
hopefully crank sensor is an old fault code ?
col
« Reply #3 on: 17 April 2009, 14:03:52 »
A paperclip wont tell you why the headlights are low,
you need a proper code reader for that.
your 19 needs attention in the form of a new crank sensor though.
2.5 / 3.0's cant report missfire either, only the later drive by wire 2.6 and 3.2's can.
Page created in 0.026 seconds with 20 queries.
