Author Topic: help!!  (Read 1049 times)
Andy1766
  • Poole Dorset
help!!
« on: 16 April 2009, 09:02:12 »
My alarm is playing up, when i set the alarm via the remote the n/s hazards lights flash only is this a sortable problem or is it better to try to change the alarm unit? help please!!!!!!
Re: help!!
« Reply #1 on: 16 April 2009, 09:19:50 »
When you put the hazard warning lights on do they all flash?
Andy1766
  • Poole Dorset
Re: help!!
« Reply #2 on: 17 April 2009, 16:57:14 »
No only the near side..
Re: help!!
« Reply #3 on: 17 April 2009, 17:22:51 »
Spend 5 minutes turning the hazard warning on/off repeatedly !!!  Seriously .. this often sorts out problems of this nature ... I believe its down to corrosion/dirt on the contacts of the hazard switch as it is infrequently used. "Exercising" it repeatedly can clean it all up .. :y :y
Might not be your problem of course.. but its a cheap fix if it is .. :)
« Last Edit: 17 April 2009, 17:23:36 by entwood »
