Author Topic: exhaust manifold on a 2.5 v6  (Read 1114 times)
animal52
« on: 17 April 2009, 19:41:52 »
I suspect that the drivers side exhaust manifold has sprung a leak and am planning to attempt it tomorrow, pls can somebody advice about the task i am going to attempt weather its a difficult one and some advice, will be much obliged. :-[
RobseyMV6
  • west sussex
Re: exhaust manifold on a 2.5 v6
« Reply #1 on: 17 April 2009, 19:55:30 »
Hi, are you sure this is your manifold and not the gasket between manifold and down pipe?
To make life easy for you, you want to pop clip off from coolent bottle unplug sensor wire and move bottle to the side also the small pump that's bolted on inner side of wing below the coolent bottle (if you should have one some do some don't) other then that it should be ok as it's the best side to do!
