Pages: [1] 2 3  All   Go Down
Author Topic: urgent. no idle on v6  (Read 15035 times)
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« on: 17 April 2009, 15:15:31 »
need urgent help, have just replaced cam belt on my elite 3.0l, i cannot get the engine to idle at all. also miss-fires at low revs. rev engine up & is as sweet as a nut. any help please. i need this car on the road pronto. thanks.  :y
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: urgent. no idle on v6
« Reply #1 on: 17 April 2009, 15:36:27 »
Retrace your steps matey.....whats been taken off, whats not in correct ? IACV completely flush and in position for example ?
The Red Baron
« Reply #2 on: 17 April 2009, 16:04:06 »
checked everything. ran out of idea`s.  :(
Bent valve
« Reply #3 on: 17 April 2009, 17:51:58 »
 Sounds like MAF sensor problem, have you checked the plug is fully pushed home ect..?
« Reply #4 on: 17 April 2009, 18:15:10 »
Air leak, was the plenum off?
Brake servo pipe ok and connected, no O rings missing or displaced between the plenum and inlet?
The Red Baron
« Reply #5 on: 17 April 2009, 18:34:04 »
plenum was off to do the cam seals. O rings seem ok.
nick v6
  • walsall / west midlands
« Reply #6 on: 17 April 2009, 19:05:18 »
that eco tech part was blocked to hell
and was leaking air real bad
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #7 on: 17 April 2009, 19:13:10 »
John has just been on the phone, asked him to do a paperclip test.
Sounds like he has the following codes..
13, 16, 17, 19
VX1
  • Reading, Berkshire
« Reply #8 on: 17 April 2009, 19:19:29 »
But did he run the engine whilst doing the test?
Paul :y
Vx Trade club card holder
Halfords trade card holder
« Reply #9 on: 17 April 2009, 19:20:02 »
Trapped lambda and knock sensor wires maybe :question
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #10 on: 17 April 2009, 19:25:08 »
I did ask if he had any wires trapped
« Reply #11 on: 17 April 2009, 19:26:25 »
And :D
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #12 on: 17 April 2009, 19:31:18 »
He says he cant see any
Just before anyone says it... no I have not done the car ;D
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #13 on: 17 April 2009, 19:31:33 »
i would be suprised if the MAf was at fault the v6s seem to run okish with the maf D/C they just cut out on the overun cutoff sometimes!!! the same as a crank sensor fault!
« Reply #14 on: 17 April 2009, 19:33:04 »
Knock sensor wire trapped wouldn`t cause uneven idle. What about the carb spray trick to definately rule out vac leaks :-/
Pages: [1] 2 3  All   Go Up
