Author Topic: check lights on  (Read 1468 times)
stevie1976
  • glasgow
check lights on
« on: 19 April 2009, 18:17:10 »
hello just new just bought 2.6cd  omega its on 52 plate done 780000 miles only problem i have is on centre con i have a check light on for coolant and window wash but both levels are fine can anyone help please :'(
3.0V6Elite
  • Salisbury
Re: check lights on
« Reply #1 on: 19 April 2009, 19:22:48 »
Are you sure that they are fine? It only needs to be a fraction out on these babies, the sensors are so sensative!
stevie1976
  • glasgow
Re: check lights on
« Reply #2 on: 19 April 2009, 19:58:04 »
yes checked them seem ok i will check again though no harm in making sure cheers :y
Re: check lights on
« Reply #3 on: 19 April 2009, 20:42:55 »
Windscreen wash sensor can get gunged up by folks using cheap additive or washing up liquid ... a good flush through might clean it.
Coolant low sensor just seems to fail, I did manage to clear one for a while by taking the whole header tank out and using a de-scaler, but it only lasted 6 months. New header tank was the decent fix .. :(
HTH
stevie1976
  • glasgow
Re: check lights on
« Reply #4 on: 19 April 2009, 20:48:53 »
thanks mate will flush and try  :y
stevie1976
  • glasgow
Re: check lights on
« Reply #5 on: 19 April 2009, 21:01:59 »
what should i flush it with
RobseyMV6
  • west sussex
Re: check lights on
« Reply #6 on: 19 April 2009, 21:20:26 »
Maybe not flush, remove grille and you should see the sensor on washer bottle tank... take out clean off and put back in with white foat facing down as for you coolant sensor maybe 40 as have been know to play up.
Can't buy just the sensor have to buy new coolant bottle but only £25 from you vauxhall outlet  :y
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Re: check lights on
« Reply #7 on: 19 April 2009, 21:22:20 »
I hope that's a typo ;D
If not, hats off to the previous owner ::)
Trade club card holder
Code scanner available
stevie1976
  • glasgow
Re: check lights on
« Reply #8 on: 19 April 2009, 21:25:13 »
yes mate i screwed up 78000 thats better :D
