Author Topic: Oil Filter  (Read 1339 times)
big-o-bob
  • Yorkshire
Oil Filter
« on: 18 April 2009, 19:14:39 »
Spent a few more hours today stripping down to change the oil cooler (Its turning into a big job).
Everything was going swimmingly until I went to remove the oil filter.  I think it must have a genuine Vx one on.  I've never seen one of these before.
I unscrewed the end and took out the filter part, but the filter housing would not come off.  I could see a allen key slot inside the housing - is this some kind of locking nut? What size?
If anyone could tell me how to get the damn thing off I would be grateful, or at least advise me on what size allen key to buy.
Is there anything worse than starting a job and not having the tools to do something!!!
Cheers ;)
« Last Edit: 18 April 2009, 19:15:28 by big-o »
Re: Oil Filter
« Reply #1 on: 18 April 2009, 19:20:44 »
Re: Oil Filter
« Reply #2 on: 18 April 2009, 19:25:12 »
Cheers ;)
If I've understood you properly &  you've removed the filter, then you've done it  :-/
What tends to happen is that the ally housing gets torqued up to silly lbs/ft and the base starts to turn aswell when you try to undo it. it should only be 15(?)Nm which is little more than being nipped up. :y
big-o-bob
  • Yorkshire
Re: Oil Filter
« Reply #3 on: 18 April 2009, 19:37:35 »
Cheers ;)
Whats happened is...I took the filter off the end and the housing is still on solid.  I bent my chain filter remover whilst trying to get it off!!!
Inside the housing I see a slot for an allen key - where it screws on to the block.
Re: Oil Filter
« Reply #4 on: 18 April 2009, 19:40:13 »
Yep, in the centre of the housing is a bolt.
and there are 2 types!
one of them is  27mm hex head, the other takes an allen key type insert...but I cant remember what size sadly (It might have been a multispline actualy!)
big-o-bob
  • Yorkshire
Re: Oil Filter
« Reply #5 on: 18 April 2009, 19:44:27 »
According to this it 27mm :o :o http://www.omegaowners.com/forum/YaBB.pl?num=1204142232
This does look like the same filter but no way is the allen key slot 27mm.
I put the biggest allen key I have (10mm)  in the slot and it is only just undersize.  At a guess I would say more like 12 or 13 mm, but not sure.
Thanks mate :y
big-o-bob
  • Yorkshire
Re: Oil Filter
« Reply #6 on: 18 April 2009, 19:47:54 »
Cheers mate.  So is it just a matter of loosening the allen key bolt then, or does the housing need screwing off in the same way as an aftermarket filter as well?
Cheers Rob
big-o-bob
  • Yorkshire
Re: Oil Filter
« Reply #7 on: 19 April 2009, 22:46:09 »
All done now cheers...it turned out to be a 12mm allen key type insert.  Got an allen key socket attachment from halfords - sorted!! :y
