Author Topic: head gaskit  (Read 1611 times)
samrey4u
  • norwich
  • Big stranglers fan
    • 2003 2.2 cd saloon
head gaskit
« on: 21 April 2009, 18:58:59 »
i have water in me oil i know its the head gaskits , can abyone advise how much i can expect to pay to have this done
sam
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: head gaskit
« Reply #1 on: 21 April 2009, 19:00:33 »
check the oil cooler it produces similar faults to a HG failure have you had a compression test done?
doubtfull to be a hg its quite rare on a v6
samrey4u
  • norwich
Re: head gaskit
« Reply #2 on: 21 April 2009, 19:02:32 »
the frothyness is inside the oil filler cap does this help
sam
VX1
  • Reading, Berkshire
Re: head gaskit
« Reply #3 on: 21 April 2009, 19:06:19 »
How does the car run? Do you do short journeys? Is the oil filler cap a white mayo in colour?
If you do short journeys the this is common on the V6 as the moisture doesn't get chance to burn off.
Paul :y
« Last Edit: 21 April 2009, 19:06:57 by vauxhallomega1 »
Vx Trade club card holder
Halfords trade card holder
samrey4u
  • norwich
Re: head gaskit
« Reply #4 on: 21 April 2009, 19:08:00 »
i only do short runs now you mention it , car seems to be running fine . is ther anything else i should look out for ? and colour is mayo also uses no oil or water
« Last Edit: 21 April 2009, 19:10:38 by samrey4u »
sam
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: head gaskit
« Reply #5 on: 21 April 2009, 19:10:16 »
what oil is in it? try using Vauxhall oil next time it seems to be more resistant to making mayo!
samrey4u
  • norwich
Re: head gaskit
« Reply #6 on: 21 April 2009, 19:12:00 »
thanks for the advise . Much appreciated not sure which oil is in it just purchased the car a few weeks ago
« Last Edit: 21 April 2009, 19:12:43 by samrey4u »
sam
HolyCount
Re: head gaskit
« Reply #7 on: 21 April 2009, 19:13:51 »
Is the only symptom you have the mayo on the filller cap ?  If so, as said above, it's the short journeys, probably not the HG.
No fluid loss at all I take it ?   Does it hold it's temp ?
VX1
Re: head gaskit
« Reply #8 on: 21 April 2009, 19:14:20 »
There you have answered your own question.
£0.00 You have just fixed your car for Nowt and without taking to the garage!!! 9999999,999999,99999,9999,999,99 to OOF 0 to Garages. :y :y :y
As you do short journeys give the car a blast down the motorway to clear it plus do more oil changes to compansate this as well.
Paul :y
samrey4u
  • norwich
Re: head gaskit
« Reply #9 on: 21 April 2009, 19:15:07 »
yep temp is fine and no loss of fluid and froth on oil filler cap thats all
« Last Edit: 21 April 2009, 19:16:20 by samrey4u »
sam
Re: head gaskit
« Reply #10 on: 21 April 2009, 19:16:12 »
Also clean out your breathers - there's a howto on here :y
VX1
Re: head gaskit
« Reply #11 on: 21 April 2009, 19:17:32 »
]Also clean out your breathers - there's a howto on here :y[/highlight]
Forgot about that one. Thanks dbug :y
Paul :y
DC
  • Switzerland
Re: head gaskit
« Reply #12 on: 21 April 2009, 19:20:33 »
and study this section of the site carefully!
it will help greatly!
samrey4u
  • norwich
Re: head gaskit
« Reply #13 on: 21 April 2009, 19:22:26 »
many thanks to one and all you have been a great help what a great site this is :) ;D :y
sam
