Author Topic: oil breather  (Read 1647 times)
stevie1976
  • glasgow
oil breather
« on: 21 April 2009, 12:24:13 »
can anyone give me advice on how to clean and what to use to clean the breather out any diagrams and advice please thanks alot  :y
ians
  • Reading
Re: oil breather
« Reply #1 on: 21 April 2009, 12:25:28 »
Take a look in the maintenance guide section - there are guides for both V6 and 4 pot in there.
You need carb cleaner and a selection of paperclip/screwdriver/wire for poking..
jjleonard
  • stevenage
Re: oil breather
« Reply #2 on: 21 April 2009, 12:32:43 »
stevie1976
  • glasgow
Re: oil breather
« Reply #3 on: 21 April 2009, 16:25:34 »
is it easy to do mate  :y
jjleonard
  • stevenage
Re: oil breather
« Reply #4 on: 21 April 2009, 16:38:36 »
Yeah, quite easy to do. Just be careful in removing the 'ecotec' box on top of the plenum, as yanking it out tends to tear the seal underneath and you'll need to replace it before you start the car.
All in all it can be done in an hour or two - depends how much gunk you have to clean out of the pipes and breather box. :y
stevie1976
  • glasgow
Re: oil breather
« Reply #5 on: 21 April 2009, 16:43:45 »
thanx for your help mate :y
jjleonard
  • stevenage
Re: oil breather
« Reply #6 on: 21 April 2009, 16:51:02 »
 ;) No probs mate.
ians
  • Reading
Re: oil breather
« Reply #7 on: 21 April 2009, 17:42:42 »
Its a bit tricky to get the big pipe off under the scuttle, but otherwise straightforward.  Just take your time and follow the guide - and don't forget to shove kitchen roll in the inlet ports just in case. :y
Re: oil breather
« Reply #8 on: 21 April 2009, 19:32:56 »
Use carb cleaner - welding rods/wire for poking out small holes :y
stevie1976
  • glasgow
Re: oil breather
« Reply #9 on: 21 April 2009, 19:39:03 »
will do thanks for advice great site :y
