Author Topic: sunroof problem  (Read 1226 times)
RolandL
  • Doncaster
    • M/facelift 2.5 V6 Elite
sunroof problem
« on: 21 April 2009, 18:09:37 »
My sunroof wont open,(switch not lit up) not very clear which fuse it is in fuse box, or if there is a relay for it. can anyone point me in the right direction.
The faster you go the bigger the grin.  Trade card user.
Ziad
  • Bahrain
Re: sunroof problem
« Reply #1 on: 21 April 2009, 20:25:02 »
try to reset the sunroof by pressing IN the sunroof button for about 5 seconds and try again.
If that does not work out for you, then:
There indeed are relays / fuses for the sunroof. And if i do recall right, they should be in the fuse both UNDERNEATH your steering wheel - there are 2 fuses for them.
F25      20A       Motor, sliding roof
F13   10A    Adjustable exterior mirrors, electric windows, sunroof, central locking system
Check them out mate  :)
RolandL
  • Doncaster
Re: sunroof problem
« Reply #2 on: 21 April 2009, 21:16:31 »
Tried that, didn't work  :(
will check fuses
cheers :y
Agemo
  • Cleethorpes
  • Insignia
Re: sunroof problem
« Reply #3 on: 21 April 2009, 21:23:54 »
You can open/close it manually with a screwdriver if it helps, it will prove it has not seized up.  ::)
