Author Topic: front end knock  (Read 1761 times)
glsboy
front end knock
« on: 21 April 2009, 19:56:06 »
hello...when i harsh brake over a bumpy road or a little pothole a bad knock appears from the front end....im guessing summet up with brakes or is it possibly shocks gone?...let us know!
star_whites
  • Rotherham
Re: front end knock
« Reply #1 on: 21 April 2009, 19:58:18 »
Its probably the front suspension drop link. Sounds like a knock and 99% of time thinks it the suspension but they are a common fault.
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Re: front end knock
« Reply #2 on: 21 April 2009, 19:58:57 »
Knocking from the front end is usually droplinks, cheap and easy to replace :y
Trade club card holder
Code scanner available
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: front end knock
« Reply #3 on: 21 April 2009, 20:00:30 »
...ooor.... if when you brake over bumps the steering pulls and wanders then it possible your wishbones need replacing
(should beable to get pattern replacement wishbones and drop links for 65 pounds on ebay)
HTH
V8!!!!
glsboy
Re: front end knock
« Reply #4 on: 21 April 2009, 20:24:21 »
no dont wander bout mate...its jus like the shockers have got no more to give abd dont absorb the bump....just drop in and jump out of them....sending judders through the car...where are the droplinks then boys??
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
Re: front end knock
« Reply #5 on: 21 April 2009, 21:31:48 »
check the springs
alexandjen
  • The Silver Surfer
Re: front end knock
« Reply #6 on: 21 April 2009, 21:34:56 »
Have a look at the pic in this link, to the left hand side............
http://www.omegaowners.com/forum/YaBB.pl?num=1219190175
jjleonard
  • stevenage
Re: front end knock
« Reply #7 on: 21 April 2009, 23:14:21 »
£8 a pair from ebay and about half an hour a side to change - i'd check the play in the wishbone bushes as well, though. :y
