Pages: [1] 2 3  All   Go Down
Author Topic: The cambelt slip - conclusion  (Read 5613 times)
« on: 19 November 2007, 19:51:11 »
Spent the whole of last night in the piddling rain, sleet, dark, and cold, getting the cam timing bang on and putting the car back together.
Bearing in mind I was working under a dodgy bit of tarpaulin, in the pitch dark, with only a maglite to see by - the job took I would estimate just over three hours.
I cranked the engine over by hand again once timed up properly, and I could again feel good compression.
Double checked everything was done properly, filled up with coolant, and Fired her up.
My three bitterly cold and wet hours paid off. She roared straight into life. Sounded a bit tappety to begin with, but I wonder if that was the OS manifold gasket, been suspicious of that for a while.
Once she got a bit warmer, and the SAI also shut up, she purred like a happy kitten :)
Then died again. Tried cranking, and she fired up, coughed, and died. Went and got a can of petrol, and all was well again  ::)
Gave it a couple of gentle revs, sounded OK. Couple of hard revs near the redline - again, no problem.
A slight "knock" when I reved it, I Traced to a loose cable tray - whoops! fixed that.
Road test - seems the same as before. The flat spot at 4krpm has now gone, so I just wonder if it didn't slip all those teeth in one go. Maybe it had slipped only three teeth instead of four, and I got away with it??
I'll compression test it again, but the way it's looking, is that I had a very lucky escape!
In addition to it now running OK, it has a brand new genuine GM cambelt kit, water pump, aux belt, and aux belt tensioner, all fitted and set up properly by myself.
I've now done approx 300 miles, all between 70-90mph, and I'm averaging 30 miles per gallon.
Fingers crossed. Looks like my LPG install can continue this weekend...  :y
« Last Edit: 19 November 2007, 19:53:58 by JamesV6CDX »
Re: The cambelt slip - conclusion
« Reply #1 on: 19 November 2007, 19:54:19 »
Oh, and I found the radio code, so the CCR2006 is also working  ;D
Omegatoy
  • UK
« Reply #2 on: 19 November 2007, 19:55:59 »
 :y really pleased for you James you deserved a bit of good luck!!!! :y
« Reply #3 on: 19 November 2007, 19:57:06 »
Congratulations on both your luck and your tenacity .. :)
« Reply #4 on: 19 November 2007, 19:58:23 »
But when we checked timing a couple of months back, it was pretty close, and it had its flat spot then?
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #5 on: 19 November 2007, 20:01:05 »
fantastic news.... and i did say on the initial posts, you may be lucky  ;)
Now buy a lottery ticket !
Danny
  • Wigan, Greater Manchester
« Reply #6 on: 19 November 2007, 20:06:39 »
tis very good news, i'm quite pleased i said dont start it last night, tho i'm not sure my post alone was a big influence  ;D
i'm thinkin, before you LPG it, run it for a month or so just to be sure it's really completely back to its good self...
STMO123
« Reply #7 on: 19 November 2007, 20:10:04 »
Thank God for that.
    • 530D M Sport, 330i Coupe
« Reply #8 on: 19 November 2007, 20:53:48 »
Brilliant result! Well done mate!
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #9 on: 19 November 2007, 21:14:07 »
What a relief, well done James :y
I like red cars
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #10 on: 19 November 2007, 21:15:15 »
glad that worked out well......now you can join the LPG fun
Dazzler
  • Haverhill, Suffolk
« Reply #11 on: 19 November 2007, 21:15:49 »
Well done James, top job :y
« Reply #12 on: 19 November 2007, 21:19:53 »
Excellent news! Flat spot cured as well :y
I'd take some compression readings just so you have a baseline, and to see if the iffy cylinders pick up when hot.
Meanwhile, in a dry garage, so no excuse there, I still haven't got SWMBO's crank pulley off. >:(
I really have tried everything now, except booking it into the stealers and sniggering as I walk out leaving it to them to figure out.  :(
« Reply #13 on: 19 November 2007, 21:23:58 »
Jaime - no, it didn't have that flat spot after we corrected the timing initially.
I've had the flat spot for about three weeks - I just wonder....
I'm thinking possibly, car conked out and shuddered just to lack of fuel (hence engine sounding awful when it died)
And the cambelt slip was maybe unrelated, just very lucky that I detected it before total failure?
You should see the top idler, it was in a BAD way!!!
« Reply #14 on: 19 November 2007, 21:25:24 »
Kevin - depending on the bolt spacing on the auxiliary part of the pulley, I have a fantastic tool made for me by sassanach, it may just help you out....
Pages: [1] 2 3  All   Go Up
