Author Topic: Valve seal removal  (Read 1204 times)
Martin_1962
Valve seal removal
« on: 22 April 2009, 19:36:58 »
Very difficult to get out
What is best way to remove them?
the-toy-maker
Re: Valve seal removal
« Reply #1 on: 22 April 2009, 20:27:04 »
do you mean valve stem seals?
if so last time i did a set of these i used a small screw driver to split the outer metal ring and then pulled the seal off with a pair of long nose pliers :)
tap the screw driver gently with a pin hammer to split the metal ring ;)
to fit the new ones i found a socket the same size as the metal outer ring and gently taped the new ones on :)
hope this helps :)
A good friend will bail you out of jail! But a true friend will be sat next to you saying we had fun!!!!!
« Reply #2 on: 22 April 2009, 21:06:32 »
Call me a bodger - always been able to tease them off with long nose pliers...
