Author Topic: valve seal replacement  (Read 2828 times)
Roger
  • Wakefield
    • 01, omega mv6 2.6
« on: 22 April 2009, 20:51:47 »
hi,
we have new valve seals to fit as the car is blue smoking on start up.
Is it possible to change the valve seals on a 2.6mv6 (01)without taking off the cylinder heads, by means of putting  1 cylinder at a time under compressed air to keep up the valves whilst the bucket and spring is removed, then remove the old valve seal and replace it with a new 1 and re-build up the valve assembly, then onto the next 1. has this been carried out before ? . this will save us a full cylinder heads stripdown.
regards martin.
HerefordElite
  • Hereford
  • Welcome to the Shire
Re: valve seal replacement
« Reply #1 on: 22 April 2009, 22:24:31 »
You'll have to remove tha cams, and how are you going to compress the valve springs to remove collets? :-?
I remember years ago i had a cvh escort (worst car i've ever owned :-[) but the one good thing was the ability to remove the rocker arm and compress springs in situ :)
webby23
  • Nottingham
  • MV6
« Reply #2 on: 22 April 2009, 22:27:31 »
I thought there was a way of replacing them in situ?
Mark DTM will correct me
iainb
  • West Midlands
« Reply #3 on: 22 April 2009, 22:29:31 »
A small amount of oil on start up means you need to change your oil and filter.
« Reply #4 on: 22 April 2009, 22:32:19 »
hi,
regards martin.
Hi Martin...
Meh - go the whole hog - remove the heads, and change the gaskets, exhaust gaskets, etc.
You know it's all done then - and it's not much more work or expense  :y
webby23
  • Nottingham
  • MV6
« Reply #5 on: 22 April 2009, 22:36:15 »
It means on a 2.6 in this year, valve stem oil seals breaked. Bad batch I heard from trusted sources.....
Mines the same too.......
iainb
  • West Midlands
« Reply #6 on: 22 April 2009, 22:42:09 »
I have a 2.5l with some 250k on the clock and it chucks out oil when it needs an oil change but only when to idle to long.
I just change the oil and filter and she's back to normal
webby23
  • Nottingham
  • MV6
« Reply #7 on: 22 April 2009, 22:55:10 »
That may well be the case for you Rusty mate but I am aware that for 6 months in production of the 2.6 they changed the seals to save a penny on each one......!!!
Ridiculous but true..........
  • Online Online
« Reply #8 on: 22 April 2009, 23:07:03 »
Oil leaks passed valve steals into the engine whenstops. Next time the engine is started, it gets burnt off, and appears as bluey exhaust.
  • Online Online
« Reply #9 on: 22 April 2009, 23:09:05 »
Probably glass hard valve stem seals after 250k ....
« Reply #10 on: 23 April 2009, 08:32:03 »
Known issue, some low life self-abuser in the GM purchasing department managed to save a penny a seal by buying inferior products!
They were fitted for around a 9 month period adn what happens is that the stem seals come off the guides and go up and down with the valves!
Not good.
Here are a few pics of one I did recently!
The seals, faulty one on the left, new on the right.
The state of the exhaust ports
I removed the heads to do this as 3.0 cams were being fitted and so they had a stage 1 port.
It can be done with the heads on (Vx have special tools for this) by applying compressed air to the cylinder and using a tool to compress the valve spring.
  • Online Online
« Reply #11 on: 23 April 2009, 09:37:47 »
....... that the stem seals come off the guides and go up and down with the valves!
Not good.
Isn't that how some older cars were original built?
......  It can be done with the heads on (Vx have special tools for this) by applying compressed air to the cylinder
I always like the idea of string fed into the bore to keep the valve held up better.  :y
Out of interest only .... what's it look like? And how does it hold on to the head
« Reply #12 on: 23 April 2009, 10:47:07 »
Not good.
Yes, as used on Rover V8's (the most over rated engine of all time!) upto the 90's where the inlet ports were the only ones with stem seals (as the inlet is the side exposed to a vaccum). These were generally just rubber washers though and not a nice bucket shape capable of forcing oil down the stem!
Fine on old fashioned push rod shite with easy access to the spark plugs and huge valve stems but, the compressed air setup does work better and has much less chance of valve damage  :y
Its a rod that bolts where 3 of the cam caps go and then a lever which attaches to it
There are a number of heads that go on it to aid with collet removal and fitting
M0T0RVATE
  • Orpington
    • 94 Omega Elite Saloon 3L
    • MOTORVATE STUDIO
« Reply #13 on: 23 April 2009, 11:09:19 »
hi,
regards martin.
Adventurous idea... :exclamation
Doubt if compressed air is good enough to withstand pressure of spring removal and replacement... :question
What if you end up with a dropped valve... :question
« Reply #14 on: 23 April 2009, 11:14:46 »
Its a standard and proven method plus it works well.
I should havd added, use a depp 10mm socket and smack the top fot eh spring/collet assembly first to unstick the upper spring mount from the collets.
