Author Topic: Driver door keeps opening .  (Read 2788 times)
Muskie
  • Stockport
« on: 23 April 2009, 21:28:51 »
Hi all ,
Having a real problem whereby the drivers door keeps opening whilst driving. I have adjusted the catch on the door pillar several times but after a while it keeps opening which is a real pain.
Any ideas would be greatly appreciated.
Thanks
Ian.   :(
Re: Driver door keeps opening .
« Reply #1 on: 23 April 2009, 21:31:53 »
you'll need to investigate/replace the catch in the door.
bigdods
  • Brackley
« Reply #2 on: 23 April 2009, 21:34:56 »
Happened to me a while back, latching mechanism was broken and had to be replaced. IIRC about £100 for the mechanism + 1 hour labour
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
« Reply #3 on: 23 April 2009, 21:36:21 »
Blimey that sounds scary  :o I dont think I would like to be driving that , maybe worth trying it with the door locked and see what happens until you get chance to investigate  :y
LFF64
  • HADDENHAM BUCKS
« Reply #4 on: 23 April 2009, 21:38:19 »
I would try looking in the for sale section and asking someone on there if they have one would be much cheaper  :y
Muskie
  • Stockport
« Reply #5 on: 23 April 2009, 21:46:08 »
How easy is it to replace the lock mechanism on the door ?
Would it be worth getting one from a scrap yard ?
Pete Elite
  • Uxbridge, Middlesex
« Reply #6 on: 23 April 2009, 21:50:23 »
Have you tried welding it up ::) ;D ;D.
LFF64
  • HADDENHAM BUCKS
« Reply #7 on: 23 April 2009, 21:51:18 »
Yes  ;) You will obviously need to take the door card off to get to it buts thts no big job , its fairly simple to take the catch out . and if you get one from a scrap yard you will have to take it out so anyway so you will get some practice at the same time  :y
« Reply #8 on: 23 April 2009, 22:59:23 »
..... and if you get one from a scrap yard you will have to take it out so anyway so you will get some practice at the same time  :y
and it won't matter if you bu66er it up! ;D  ;D Just move on to the next car ...... they were thin on the ground though when I looked last week end.  :-/
« Last Edit: 23 April 2009, 22:59:36 by Andy_B »
« Reply #9 on: 23 April 2009, 23:53:03 »
A less permanent solution is to open the window by about 1", together with window on the back door.  A piece of cord passed throught the 2 windows and knotted will keep the door shut while driving yet when undone will allow easy access/exit.  Alternatively you can use a cable tie which can be cut to allow exit. Hope this helps :-? :-? :-? ::) ::) ::)  ;D ;D ;D
Pete Elite
« Reply #10 on: 24 April 2009, 00:10:34 »
   Oh come on dbug be sensible, what about the aesthetics and the wind noise ;D ;D ;D.
« Reply #11 on: 24 April 2009, 00:14:57 »
Tie a neat knot eg a bow - wont look out of place :P
Wind noise will be less than when driving at speed with the bl**dy door open :) ;)
« Last Edit: 24 April 2009, 00:15:26 by dbug »
Pete Elite
« Reply #12 on: 24 April 2009, 00:18:31 »
     Yeah but not half as exciting though :o :D ;D.
« Reply #13 on: 24 April 2009, 00:25:28 »
Yeah remember when I bought my TR4A in Bedford many years ago - it had been wrapped round a lamp post and drivers door was banana shaped with no glass in it. Had to hold it shut to on drive home - very exciting as I managed to hit 110 mph on the A6 with the big ends knocking like hell and massive wheel wobble.  (Knew the problems when I bought it and totally rebuilt all mechs etc.  Done the bodywork - it was brg (green) but resprayed it red as this made my thingy 1" longer ::) ::) ;D ;D ;))
[edit]For thingy read willy - word filter strikes again ;D[/edit]
« Last Edit: 24 April 2009, 00:27:47 by dbug »
p j morgan
  • nottingham
« Reply #14 on: 24 April 2009, 00:27:50 »
its not even a open and shut case! try dave marshall i think he has some front doors off a silver elite hope that helps :y
Page created in 0.187 seconds with 14 queries.
