Author Topic: Engine heat shield  (Read 1103 times)
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Engine heat shield
« on: 24 April 2009, 12:15:59 »
I have a loose heat sheild on the engine drivers side , it looks as if the front secruing bolt has pulled through the shield , so plan was to remove the bolt and fit a washer to cover the enlarged hole .
 Problem  is the bolt will not shift . Question is do I just put up with the rattle as I do not think the bolt will shift or what problem would be caused by removing the sheild all together  :y
Re: Engine heat shield
« Reply #1 on: 24 April 2009, 12:18:38 »
I find none, as mine has lost it long ago!! 8-) 8-)
Easier access is the result! 8-) 8-) 8-) ;)
ians
  • Reading
« Reply #2 on: 24 April 2009, 13:10:19 »
I believe having it in place improves air flow and hence cooling.
« Reply #3 on: 24 April 2009, 14:56:04 »
I'd try to keep it in place if possible.
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #4 on: 24 April 2009, 17:03:58 »
if its broken like mine did around the bolt all i did was fit a huge washer to cover the hole and bolted it back on
tried mole grips on the bolt ?? i used bruteforce and mole grips
« Last Edit: 24 April 2009, 17:04:28 by tmx »
LFF64
  • HADDENHAM BUCKS
« Reply #5 on: 24 April 2009, 18:50:39 »
Yes it has broken around the bolt and the bolt wont shift  ::)
