Author Topic: Timing Belt  (Read 2086 times)
over50now
  • Hertfordshire
Timing Belt
« on: 23 April 2009, 19:33:05 »
Evening,
in the process of doing my timing belt   2.5 v6.   using Marks DVD (fantastic).  Have hit a problem tho.  Crank pulley won't come off.  Yep all bolts out, tapped it with rubber mallet. whacked it a bit more with the rubber mallet, spoke to it nicely, threatened it but still won't budge.  Any ideas please :-[ :-[
IAM & ROSPA Gold Grade driver
serek
  • huntingdon
    • 3.2 mv6
Re: Timing Belt
« Reply #1 on: 23 April 2009, 19:37:44 »
use some WD-40  I had same problem with PAS wheel , so use spray and hummer :D and come off , dont knock to strong you dont do any damage
« Last Edit: 23 April 2009, 19:38:45 by serek »
over50now
  • Hertfordshire
Re: Timing Belt
« Reply #2 on: 23 April 2009, 19:39:08 »
thanks serek :y
Re: Timing Belt
« Reply #3 on: 23 April 2009, 20:13:09 »
You will just need to beat it off, I'm afraid. Rubber mallets are good :y
Re: Timing Belt
« Reply #4 on: 23 April 2009, 21:15:06 »
They do stick sometimes, but it will eventually come off :)
Re: Timing Belt
« Reply #5 on: 24 April 2009, 00:18:10 »
Use a broom handle and a bl**dy big hammer and give it a good welt or two.  This got mine off OK.
Cybertrucker
  • Lichfield, Staffs
Re: Timing Belt
« Reply #6 on: 24 April 2009, 12:57:26 »
Never done one on a Miggy, but I've done several on Sierras, and I found that you need to exert the pull on both sides of the pulley at the same time so you're trying to pull it off square - if you just heave on one side of the pulley it binds and is much harder to get off, if it comes off at all.  I used to use two bars, or beefy screwdrivers.
HTH
« Last Edit: 24 April 2009, 14:36:06 by cybertrucker »
http://www.cybertrucker.co.uk - Truck stuff
http://www.abd.org.uk - Association of British Drivers
My other car is a Granada.
My other other car is a Dennis.
over50now
  • Hertfordshire
Re: Timing Belt
« Reply #7 on: 24 April 2009, 18:28:24 »
Thanks everyone.
Got other advice today:-
Use a king great lever.
Now is that a discription of a specialist tool??
Similar to a long weight. :-/
Comments please
Re: Timing Belt
« Reply #8 on: 24 April 2009, 20:29:36 »
2 welts on my cut down broomhandle (one each side) and it fell off :y
Use of a 'king great lever may damage front plastic cover :(
« Last Edit: 24 April 2009, 20:31:23 by dbug »
Bumbazor
  • Worksop
Re: Timing Belt
« Reply #9 on: 24 April 2009, 20:33:10 »
Probably means a ***king great lever
« Last Edit: 24 April 2009, 20:33:30 by Bumbazor »
stevie1976
  • glasgow
Re: Timing Belt
« Reply #10 on: 24 April 2009, 21:41:49 »
try even pressure at both sides and a good hit try the broom handle the wood wont damage it :y
