Author Topic: HELP!!! snapped 22mm union bolt  (Read 9322 times)
kingplym
  • camden, hatfield, st.neots
  • sports on, kick down
« on: 22 April 2009, 15:46:54 »
as i was undoing the coolant bridge unioin bolts the left one snapped/twisted of, the head span off with the threaded part of the bolt still in the block :o :o :o
1. can someone please send me a bolt asap to arrive for tomorrow, i will pay vauxhall said friday cos after 3pm
2. how do i get the threaded part of bolt out? im not mechanically trained in any way i am a lowley electrician please help anyone
« Last Edit: 22 April 2009, 16:36:37 by kingplym333 »
i am willing to trade my electrical labour for parts work etc
Re: snapped 22mm union bolt
« Reply #1 on: 22 April 2009, 15:51:44 »
had this happen to me, how much is left of the bolt?
I jammed something like a coin or thin metal bar across the bolt and managed to rotate it out.
kingplym
« Reply #2 on: 22 April 2009, 15:55:38 »
mine aint coming lose i think its rotted in? :'( :'( :'(
serek
  • huntingdon
    • 3.2 mv6
« Reply #3 on: 22 April 2009, 16:04:36 »
had same problem with mine  >:( before, need buy new oil cooler afrer
« Reply #4 on: 22 April 2009, 16:17:09 »
Think I have a spare, and If so should be able to post tomorrow
It's happened to me in the past too. Hence why this time, I have ordered all new ones, for my next rebuild  ;D
kingplym
« Reply #5 on: 22 April 2009, 16:23:02 »
i cant get it out? the cooler bridge left hand side? what do i do???
« Reply #6 on: 22 April 2009, 16:24:35 »
Can you get some long nosed pliers on any part of the snapped bolt, or carefully tap it around with something?
kingplym
« Reply #7 on: 22 April 2009, 16:35:34 »
ive tried tapping it round but its not having it. it is really wedged in, will not come loose :'( :'( :'(
i dnt know what to do i am really losing my sense of humor and am getting quite stressed :o :( >:(
« Reply #8 on: 22 April 2009, 16:37:23 »
Can you confirm if there is anything to "get hold of" or has it snapped flush?
Also.... Heat might help.....
kingplym
Re: HELP!!! snapped 22mm union bolt
« Reply #9 on: 22 April 2009, 16:50:23 »
yes there about 10mm to get  to get hold of.
by heat do you mean like a blow torch?
« Reply #10 on: 22 April 2009, 16:51:29 »
Can you get some mole grips on it?
kingplym
« Reply #11 on: 22 April 2009, 16:53:43 »
not enough room to maneuver
kingplym
« Reply #12 on: 22 April 2009, 17:33:07 »
please someone the more im trying to free it the more any purchase sides are wearing away :'(
unlucky alf
  • worksop, notts
« Reply #13 on: 22 April 2009, 17:44:06 »
is there any way you could give it a smack with a hammer?, as this can often break the corrosion holding it & then mole grip it out ;)
« Reply #14 on: 22 April 2009, 18:33:52 »
I would spray penetrating oil(not wd40) on it and leave for an hour or so,then tap the top of it with a hammer sharply to try to crack the corrosion,then try turning it.
