Author Topic: Is the Hxxxx Key Number...  (Read 1393 times)
MutantCav
  • Gainsborough
« on: 25 April 2009, 09:16:20 »
the physical code to have a replacement cut, or the electronic code for the immobiliser???
Where can I find the immobiliser code and the central locking code assuming its the physical key code number or how can a blank one be programmed???
    • 530D M Sport, 330i Coupe
Re: Is the Hxxxx Key Number...
« Reply #1 on: 25 April 2009, 11:23:30 »
Hxx is the blade style IIRC
You program the immobiliser to recognise the chip in the key (the immobilser chip in the key has a code in it already) hence you need the immobiliser security number from the Car Pass.
Done a few now on the Opelscanner without problem.
« Reply #2 on: 25 April 2009, 11:27:05 »
Key number is the mechanical key cutting code.  Blade style is 105.
Immob code is the one for transponders and remotes.
