Author Topic: Storing my Mig...  (Read 4724 times)
Storing my Mig...
« on: 25 April 2009, 12:15:06 »
Hi All,
I might have the chance to work abroad for a couple of years and I'm thinking of storing my Mig rather than sell it... :)
Apart from disconnecting the battery, what should I do to ensure its going to be OK when I need it again?
Many Thanks in advance :y :y
Re: Storing my Mig...
« Reply #1 on: 25 April 2009, 12:42:33 »
Ideally get it inside, remove plugs and a drop of Light oil down the wells, remove wheels and lay flat and obviously, remove battery.
TBH, is it actually worth storing it? with the current prices I can't see it being worth it IMHO :y :y
« Reply #2 on: 25 April 2009, 12:50:59 »
Well, to be honest its with prices in mind that I'm thinking of storing it, as I've got a garage where I can keep it for free.
As you say its not worth much, but I'll have a decent car when i get back! :y
« Reply #3 on: 25 April 2009, 16:24:13 »
i would be tempted to store mine if i worked abroad, after all its barely worth 4 figures, be lucky to get £800 for mine now which is nothing.
If you can store for free, why not!  8-)
« Reply #4 on: 25 April 2009, 17:31:57 »
Thats exactly what I'm thinking Tunnie, save all the hassle of buying another when I get back!! :y
I've come back from working abroad before, despretly needing wheels and bought a pile of you know what!! :( ;D
Omegatoy
  • UK
« Reply #5 on: 25 April 2009, 18:51:34 »
If your going to store it then  full wash and dry and a coat of wax all over,just before you put it in the garage on blocks or axle stands to stop the tyres from squaring off, do a complete oil and filter change to stop the contaminants in the old oil from causing the bottom end to corrode, clean out inside and put a few satchets silica gel? the stuff that absorbs damp(cant remember what its called )doh!! worst case tho is if its an auto, normal proceedure to store an auto box is to fill it brimful of auto fluid to stop the clutch bands drying out at the top and destroying themselves when you start to use it again, as no dipstick on the omega ones not to sure how you can brim it ? certainy you can over fill it but dont know how your going to know how far up it is?
fill or a least squirt all locks with as much grease as you can get in there(motorbie chain lube is good for this as it comes out a liquid and then reverts to grease when its solvents disperse,designed to get in the links but of course it gets in everywhere you use it!! dont forget the ignition lock, try to make sure the garage is well ventilated to allow any moisture left on car underneath to dry off so the car wont sweat or condensate in there, :y
steverubberduck
  • Kidderminster
  • MV6 BABY!!!!!!!!!!!
« Reply #6 on: 25 April 2009, 19:07:27 »
some good info there.
if i was going to be working abroad i'd want to store mine aswell.
I agree with the oil change, silica gel, standing on axle stands, and giving the car a good going over.
Even if some of the stuff sounds like a little overkill, you know that when you come home, that your car will be in a mint condition.
« Reply #7 on: 25 April 2009, 20:13:13 »
That is perfect advice... Silica Gel is something I hadn't thought of ::) ::) ::)
I agree... If storage is free then do it :y :y :y
Omegatoy
  • UK
« Reply #8 on: 25 April 2009, 20:24:14 »
glad you approve guys its what i used to do with my MK11 Zodiac convertible, when the show season was over for its winter hibernation!!,
did it every time and never had a problem with anything on it by the way one thing i forgot was if you have an electric ariel put it up and oil  the stem then put it back down to keep it free  from sticking
« Reply #9 on: 25 April 2009, 20:24:35 »
How about one of these?
« Reply #10 on: 25 April 2009, 20:30:08 »
Nice idea Andy, but my cars not worth much more than that!! ;D ;D ;D
I think a few old bed sheets will do the trick!! :y :y :y
steverubberduck
  • Kidderminster
« Reply #11 on: 25 April 2009, 20:35:22 »
wowwwww, thats amazing, a bit overkill, but looks that part.
good find  :y
« Reply #12 on: 25 April 2009, 20:43:11 »
Nice idea Andy, but my cars not worth much more than that!! ;D ;D ;D .......
I'd meant to add a few ..  ;)  ;)  ;)  ;) .... but didn't :-[. You never know, we might very well see a few Omegas ( I don't drive a bl00dy Mig!  :-? I weld with one  ;)) instead of Mk II Jags etc in them one  day! ..... as long as all the modern day electrickery holds out!  ;) ;)  :y  :y
« Last Edit: 25 April 2009, 20:43:41 by Andy_B »
« Reply #13 on: 25 April 2009, 20:44:31 »
good find  :y
You don't read Practical Classics etc ......  ;)
« Reply #14 on: 25 April 2009, 20:57:34 »
If I don't come back, it may get discovered in years to come as a rare vintage classic!!  :D ;D :D ;D
