Author Topic: Dashboard gauges just stopped working!! HELP!!  (Read 1143 times)
trademeister
  • Rotherham
« on: 25 April 2009, 23:50:52 »
I was fitting a stereo yesterday and think I must have shorted something out :'( :'(! The stereo now just flashes on and off but more importantly all my dash clocks including the speedo, milometer, rev counter, fuel and temp gauges are now not working!! Can anyone tell me if theres a fuse that controls these and if so where???? Thanks again for your help. Mark
Re: Dashboard gauges just stopped working!! HELP!!
« Reply #1 on: 26 April 2009, 00:08:00 »
Will be one of the ones up under steering wheel
Ziad
  • Bahrain
« Reply #2 on: 26 April 2009, 04:43:27 »
Easily sorted out by checking the plugs as TB said. Just check the fuse box under your steering wheel. Happened to me once .... but unfortunately my memory seems to be getting worse :( :( :( can't recall which one i replace to get them all working  ;D ;D ;D
But i guess it wouldn't hurt if you could checked these:
Fuse 6   Radio, infotainment system  RATING: 20 A
Fuse 12 Courtesy lamp, electronic air conditioning, hazard warning lights, information display, radio, infotainment system RATING 20 A
and
Fuse 15 Reverse lamps, level control, Vauxhall alarm system, seat and mirror adjustment, information display, heated rear seats, control indicators, instrument illumination, cooling fan, headlamp range adjustment RATING 20 A
Hopefully. that will do the trick for you  ;) :y
daisy
  • wales
« Reply #3 on: 26 April 2009, 11:03:17 »
 I found it was not fues 14 that had blown, but fuse 15.
My car is a 2.2 cd auto ( 2000 yr) if that makes any differents
